Re: 3.3/3.8 tensioner and idler pulleys ?
[Re: moparx]
#2726140
12/22/19 03:07 PM
12/22/19 03:07 PM
Posts: 30,451 Florida STAYcation
dOoC
The village idiot's idiot
Florida STAYcation
Thx guyz ... and MopX Yes it is a CarrotVan... 2005 ... and something that I should have mentioned... it seems like there is a slight pulley noise that gets slightly worse when you flick the AC on. The noise seems to be only noticeable at idle. The potential tensioner belt flutter ? ... don’t think I have that issue but I’ll check for free movement of that piece. That whole package ? Around 160$ Again ... is the pulley on the tensioner the same as the idler ?
[Re: dOoC]
#2726142
12/22/19 03:32 PM
12/22/19 03:32 PM
Posts: 21,442 It's a dry heat
gtx6970
It's a dry heat
No
[Re: Sniper]
#2726204
12/22/19 06:41 PM
12/22/19 06:41 PM
dOoC
Florida STAYcation
For a 2005 Dodge Caravan with a 3.3 RA lists multiple kits, staring at $52 from Gates, up to $120 for a Dayco one that also includes the alternator over running pulley, if you have one.
Where did you pull up those prices ? And WHERE did they come up with these prices ? Almost 190$ !!
[Re: Sniper]
#2726303
12/23/19 03:30 AM
12/23/19 03:30 AM
Posts: 6,003 Salem
Grizzly
Moparts Proctologist
Salem
Not sure why anyone buys a new tensioner when all you have to do is remove the pulley wheel, open the rubber seal on the bearing and grease it with a needle. Pack the grease in with your fingers and put it back together. I've never bought a new tensioner.or idler wheel. For that matter, one of my serpentine belts is almost 20 years and 300,000 plus miles old. Never had a problem.
Mo' Farts
Moderated by "tbagger".
[Re: Sniper]
#2726327
12/23/19 08:58 AM
12/23/19 08:58 AM
dOoC
Florida STAYcation
38398K shows up for a mid 90's minivan. I thought you had a 05 Caravan?
I got the prices at RockAuto. In the deals section here there is even a discount code. Snip ..., that’s the number that came up on the ebay search .,. RA ? ... never bought anything from them. When I did a past search on wheel bearings, water pumps and a radiator... their prices on that stuff was way more than ebay STILL have to pose that Q ... how did that seller come up with those numbers for that package? OR is that jsta wishful thinking and hoping on the part of the seller. ?
[Re: Grizzly]
#2726328
12/23/19 09:04 AM
12/23/19 09:04 AM
dOoC
Florida STAYcation
Not sure why anyone buys a new tensioner when all you have to do is remove the pulley wheel, open the rubber seal on the bearing and grease it with a needle. Pack the grease in with your fingers and put it back together. I've never bought a new tensioner.or idler wheel. For that matter, one of my serpentine belts is almost 20 years and 300,000 plus miles old. Never had a problem. Grizz ... interesting perspective! I’ll look into that. And that belt situation? I’m NO PRO at doing tons of 3.8 stuff but I’ve never seen a belt that was deteriorated beyond use OTHER THAN one that was in a car with a missing shield.
[Re: dOoC]
#2726456
12/23/19 08:17 PM
12/23/19 08:17 PM
gtx6970
It's a dry heat
I got the prices at RockAuto. In the deals section here there is even a discount code. Snip ..., that’s the number that came up on the ebay search .,. RA ? ... never bought anything from them. When I did a past search on wheel bearings, water pumps and a radiator... their prices on that stuff was way more than ebay STILL have to pose that Q ... how did that seller come up with those numbers for that package? OR is that jsta wishful thinking and hoping on the part of the seller. ? Ive never had a tensionor issue due to the pulley bearing. Its always been the spring / pivot where the 2 halves connect
[Re: 451Mopar]
#2726755
12/25/19 10:07 AM
12/25/19 10:07 AM
dOoC
Florida STAYcation
Check Rock Auto, less than $100 for the Enhanced Kit (Upgraded kit) Thx 51 ... do you have a link for that ? I have had VERY BAD luck searching for parts on RA in the past ..
[Re: sthemi]
#2726978
12/26/19 08:15 AM
12/26/19 08:15 AM
dOoC
Florida STAYcation
the spring loaded idler is no fun to change. did one on my 2000 t&c a few years back. splain please !
[Re: sthemi]
#2727052
12/26/19 01:00 PM
12/26/19 01:00 PM
gtx6970
It's a dry heat
the spring loaded idler is no fun to change. did one on my 2000 t&c a few years back. how so ? I've changed hundreds of them and to me they're a piece of cake . A 15mm box wrench ( long version helps ) and a belt tension-er tool with a 1/2" adapter on it is all you need. FYI, to me the easiest way to change them is from below with the car on a lift . but it can be done on jack stands
[Re: gtx6970]
#2727116
12/26/19 04:44 PM
12/26/19 04:44 PM
dOoC
Florida STAYcation
getX ... hundreds of them ? So there is or is not a grease option? stumpster ..... don’t need a YouTube vid on this ... honestly I’ve had the shield off but never looked at the pulleys as a r and r project but IIRC it’s jsta 2 bolts total for both units. Interesting bit of trivia ... on the sealed front wheel bearings.., how many times do they spin 360 degrees during 200,000 miles ? Then THESE pulleys ...
