Re: Tach drive distributor
[Re: 340Cuda]
#2724614
12/16/19 08:12 PM
12/16/19 08:12 PM
Posts: 1,229 In The Hills
jughed
In The Hills
Most I have seen are steel and I think everything is the same as the other Prestolite distributors. However there are some aluminum ones out there and I know they use a different tach cable. I don't know what else might be different about them. i have had both iron and alum., both used the same cable.
[Re: jughed]
#2724624
12/16/19 08:40 PM
12/16/19 08:40 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
Accel cap and rotor is pn 8330......since they moved to china....every rotor i have gotten from them has broke...and I super glued it to fix it....
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: jughed]
#2724764
12/17/19 11:48 AM
12/17/19 11:48 AM
Posts: 3,518 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
Most I have seen are steel and I think everything is the same as the other Prestolite distributors. However there are some aluminum ones out there and I know they use a different tach cable. I don't know what else might be different about them. i have had both iron and alum., both used the same cable. My milage varied. I have clear memories of taking the cable to a speedometer shop to have the end replaced on the cable. In your experience was there anything else that was different (or not) between the two flavors of these distributors?
[Re: 340Cuda]
#2724829
12/17/19 02:18 PM
12/17/19 02:18 PM
Posts: 755 Rochester, PA (near Pittsburgh...
1974 474 Duster
Pretty sure my later aluminum style uses all the same parts as the older cast units. Just lighter overall, the tang on the cable I was told is a .120". If anyone knows for sure or has a spare cable for sale let me know. Need the female square end on the tach side as its a Moroso tach. Thanks for all the input See ya, Ken Michalik
[Re: 340Cuda]
#2725042
12/18/19 08:24 AM
12/18/19 08:24 AM
jughed
In The Hills
Most I have seen are steel and I think everything is the same as the other Prestolite distributors. However there are some aluminum ones out there and I know they use a different tach cable. I don't know what else might be different about them. i have had both iron and alum., both used the same cable. My milage varied. I have clear memories of taking the cable to a speedometer shop to have the end replaced on the cable. In your experience was there anything else that was different (or not) between the two flavors of these distributors? The tach drive distributors that I used were Direct Connection/MoPar Performance electronic ignition types. Only difference was the weight. Not sure if posts from another site are permitted...but here goes. Read post #10. Maybe it explains the difference of the cable ends.?.? https://www.forabodiesonly.com/mopar/threads/manual-tach-drive-distributor.385232/
