Holley 750 on a stock 440 intake - what's needed? #272386
03/31/09 11:18 AM
03/31/09 11:18 AM
My hovercraft is full of eels
DaveKanofsky Offline OP
I'm sure this has been done a million times -
I'm putting a Holley list 3310-3 (750 cfm vac. sec.) on my 440 with a stock iron intake manifold. It's in a '69 Charger.
I found that the linkage would need almost a 3/4" carb spacer to clear the intake in the choke area, which causes me hood clearance concerns with the stock unsilenced air cleaner.
Any ideas for modifications that will buy me some clearance? I'm not crazy about grinding the intake if I can avoid it.
Thanks for your input and ideas!
MOPARS ONLY!
'69 Daytona, '16 Plum Crazy Challenger, '12 Durango, '01 Sebring conv't
Chaplain, Racers For Christ (http://teamrfc.org/)
John 3:17
Re: Holley 750 on a stock 440 intake - what's needed? [Re: DaveKanofsky] #272387
03/31/09 11:50 AM
03/31/09 11:50 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Drop base air cleaner base , Ford motorsport sells a 13" air cleaner that fit the holley prefectly and uses the same size airfilter as your factory unsilenced unit .
You pretty much have it figured out , the intake is the issue in the choke area , in 1970 the choke design was changed and it allows a holley to be bolted on without any mods to the intake .
Re: Holley 750 on a stock 440 intake - what's needed? [Re: DaveKanofsky] #272388
03/31/09 11:53 AM
03/31/09 11:53 AM
I had a '71 Chrysler 300 engine that had a factory cast iron intake that used a Holley bolt pattern. No need for spacers and worked perfect. I don't have a casting # handy but it had the square bore dual ovals under the carb rather than the big and little Thermoquad holes.
Re: Holley 750 on a stock 440 intake - what's needed? [Re: DaveKanofsky] #272389
03/31/09 12:08 PM
03/31/09 12:08 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
First for the linkage to clear you need about a 3/8ths spacer, they use to be pretty easy to find but I haven't seen one in years...But 1/2" ones are avalible....Also if your running a stock intake you should have more room than you seem to think.. Try losely wadding up a few balls of tin foil & place them around your aircleaner & shut your hood, that will give you an accurate idea of how much room you really have...
BTW you'll need a holley/mopar throttle adapter...
Re: Holley 750 on a stock 440 intake - what's needed? [Re: 1_WILD_RT] #272390
03/31/09 12:17 PM
03/31/09 12:17 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'd go w/ a 1/2" 4 hole spacer. It will make every thing clear and give you a few more HP Plus it will keep the carb off the HOT intake. You can also mount your fuel line backwards so it won't dump right into the distrib.
Re: Holley 750 on a stock 440 intake - what's needed? [Re: Mr.Yuck] #272391
03/31/09 12:33 PM
03/31/09 12:33 PM
Az
Crizila Offline
Crizila  Offline
Az
Dave, I have a 1/2" 2 hole ( oval holes) spacer you could try if you want. If it will work, it's yours.
Fastest 300
Re: Holley 750 on a stock 440 intake - what's needed? [Re: Mr.Yuck] #272392
03/31/09 01:00 PM
03/31/09 01:00 PM
Witness Protection Program
Kudakidd Offline
Kudakidd  Offline
w/ Swingin. Also use that drop base air cleaner unit . Moroso and others make them,
Re: Holley 750 on a stock 440 intake - what's needed? [Re: Kudakidd] #272393
03/31/09 01:59 PM
03/31/09 01:59 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Yes Moroso and other make a drop base but the FORD MOTORSPORT unit is the ONLY one uses the same filter that fits the stock unsilenced air cleaner . Moroso and others use a 14" filter element
Re: Holley 750 on a stock 440 intake - what's needed? [Re: JohnRR] #272394
03/31/09 02:16 PM
03/31/09 02:16 PM
Thanks all, I sincerely appreciate your inputs.
I started out trying the Mr. Gasket #97 heat dissipators that add up to 1/4", but they just aren't tall enough to clear the '69 intake.
John, you have a PM.
MOPARS ONLY!
John 3:17
Re: Holley 750 on a stock 440 intake - what's needed? [Re: JohnRR] #272395
03/31/09 02:21 PM
03/31/09 02:21 PM
Central Illinois
Don_440 Offline
Don_440  Offline
Central Illinois
I think you are going to need holleys linkage adapter too,keeps kick down linkage at right angle so it work properly,drop base air cleaner may interfer,might want to watch for that also
Re: Holley 750 on a stock 440 intake - what's needed? [Re: Don_440] #272396
03/31/09 02:46 PM
03/31/09 02:46 PM
I do have the linkage adapter, I will certainly look for intereference if I change the air cleaner base.
Thanks for the advice.
