bolt in sprag failure
#272189
03/31/09 01:31 AM
03/31/09 01:31 AM
Posts: 4,647 aotearoa
rebel
aotearoa
just when my racecar is going great the auto has a failure. last run went bad, big revs, no real power. change gear & the shift light stays on. it has all the good parts. an A&A ultimate LBA brake, steel drum, billet servos, reds, steels, deep pan, bolt in sprag etc... when it was pulled apart the bolt in sprag has failed & fallen apart & the case has broken where the bolt in sprag is fitted. with a LBA brake i thought the sprag is not under any duress so what would cause this? the bolt in sprag not in tight? any educated opinions out there? oh yeah. the car weighs 2950lbs, engine produces 700 hp, has a fan assisted cooler that stays under 200* auto is freshly built. it has been passing a lot of fluid out the breather since the rebuild but not too much to run out of fluid on a run, maybe a mouthfull if you could imagine that much. ![](/ubbthreads/images/graemlins/puke.gif)
Re: bolt in sprag failure
[Re: 451Mopar]
#272192
03/31/09 07:52 AM
03/31/09 07:52 AM
Posts: 762 Southington Ct.
turbobitt
Southington Ct.
A failure like this makes me wonder if it was damaged during installation. I think the A&A outer race is powder metal or at least it looks that way. If it wasn't drawn in evenly it may have cracked.
1970 Challenger w/572 Hemi street car and my pride and joy.
1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno.
1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
[Re: turbobitt]
#272193
03/31/09 08:02 AM
03/31/09 08:02 AM
Posts: 11,179 Atco NJ
DJVCuda
Atco NJ
Mopar Enthusiast has an article in this months issue covering this - It's a free read onthe internet right now starts on page 41 www.moparenthusiast.comthe A&A sprag race is made from billet steel and not powdered meta.
[Re: 451Mopar]
#272194
03/31/09 08:11 AM
03/31/09 08:11 AM
DJVCuda
Atco NJ
Was that the 4-bolt 12 roller sprag or the 6-bolt 16 roller sprag? Any idea where the sprag failure point was?
It sounds like a 12 roller, since the high revs leads me to believe that the sprag rolled over, the 16 roller design does not allow that to happen. Bolt in sprags fail, they just dont take a steel drum out with them, and make them explode, the shaft is still spinning 2.2x rpm speed and will take out the next weakest link, in this case the case itself and sprag race.
[Re: rebel]
#272198
03/31/09 12:41 PM
03/31/09 12:41 PM
Posts: 16,932 NC
440Jim
NC
This makes me think other things got broke, and your disassembly confirms it. If only the sprage wasn't holding, shifting to 2nd should have been OK. Also the LBA
[Re: rebel]
#272206
04/01/09 12:51 PM
04/01/09 12:51 PM
A while a go there was discussion about doing a burnout in second. If you have a low horsepower car maybe but I have been doing a burnout in high gear only with no issues at all. I'm not say this is why you had a failure but you never know! Quote:
trans man tells me i've been off n on the pedal all the time but i'm not. he even says i shouldn't start the burnout in 2nd. i'm no john force on the burnout. i start in 2nd & as soon as i see smoke by the window i shift into 3rd & release the linelock & ease off the pedal. does that sound right? slicks still have depth dots @ the end of season so i'm not overkilling it. burnout limiter is set @ 6500 on a 5500 stall converter. when daughter gets home i'll take a pic & post it. it was a 4 bolt sprag.
[Re: 451Mopar]
#272207
04/01/09 12:56 PM
04/01/09 12:56 PM
Posts: 1,131 Thigh-Gap Junction
New user name, Same old jerk!
Thigh-Gap Junction
I have been told the 12-element sprags (4-bolt) really are not any better than the stock one, and they were supposed to be a fix for sprags that were loose in the case?
I guess I wasn't being a total dilweed when I bolted in the original one without taking it out. And once I had 4 bolts in, adding the other 2 wasn't much more work. So far so good. ![](/ubbthreads/images/graemlins/luck.gif)
[Re: rebel]
#272208
04/01/09 03:37 PM
04/01/09 03:37 PM
turbobitt
Southington Ct.
Is it just me or does this thing look like it got hot ? Maybe lack of oil lub somehow? Is there any galling on the mainshaft or governor support(or whatever they call it)? Allan G.
