bolt in sprag failure #272189
03/31/09 01:31 AM
03/31/09 01:31 AM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
just when my racecar is going great the auto has a failure. last run went bad, big revs, no real power. change gear & the shift light stays on. it has all the good parts. an A&A ultimate LBA brake, steel drum, billet servos, reds, steels, deep pan, bolt in sprag etc... when it was pulled apart the bolt in sprag has failed & fallen apart & the case has broken where the bolt in sprag is fitted. with a LBA brake i thought the sprag is not under any duress so what would cause this? the bolt in sprag not in tight? any educated opinions out there?
oh yeah. the car weighs 2950lbs, engine produces 700 hp, has a fan assisted cooler that stays under 200* auto is freshly built. it has been passing a lot of fluid out the breather since the rebuild but not too much to run out of fluid on a run, maybe a mouthfull if you could imagine that much.
Re: bolt in sprag failure [Re: rebel] #272190
03/31/09 05:34 AM
03/31/09 05:34 AM
OZ
CRIKEY Offline
super gas
CRIKEY  Offline
super gas
OZ
any pics?
I have seen the outer sprag ring break when fitted incorrectly, is it possible it could have been cracked?
Re: bolt in sprag failure [Re: rebel] #272191
03/31/09 05:40 AM
03/31/09 05:40 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Was that the 4-bolt 12 roller sprag or the 6-bolt 16 roller sprag? Any idea where the sprag failure point was?
Re: bolt in sprag failure [Re: 451Mopar] #272192
03/31/09 07:52 AM
03/31/09 07:52 AM
Southington Ct.
turbobitt Online content
turbobitt  Online Content
Southington Ct.
A failure like this makes me wonder if it was damaged during installation. I think the A&A outer race is powder metal or at least it looks that way. If it wasn't drawn in evenly it may have cracked.
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
Re: bolt in sprag failure [Re: turbobitt] #272193
03/31/09 08:02 AM
03/31/09 08:02 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
Mopar Enthusiast has an article in this months issue covering this - It's a free read onthe internet right now starts on page 41
www.moparenthusiast.com
the A&A sprag race is made from billet steel and not powdered meta.
Re: bolt in sprag failure [Re: 451Mopar] #272194
03/31/09 08:11 AM
03/31/09 08:11 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
It sounds like a 12 roller, since the high revs leads me to believe that the sprag rolled over, the 16 roller design does not allow that to happen. Bolt in sprags fail, they just dont take a steel drum out with them, and make them explode, the shaft is still spinning 2.2x rpm speed and will take out the next weakest link, in this case the case itself and sprag race.
Re: bolt in sprag failure [Re: turbobitt] #272195
03/31/09 08:20 AM
03/31/09 08:20 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Replaced more bolt in sprags(over running clutchs)than stock.Just changed out a bad super sprag in Dave Ross's Coan trans.Although it had more rollers and springs,the rollers/springs were much smaller than the stock ones as well as the ramp ring housing.Many of the springs were broken or flat and the inner race(ring) had obvious chatter(flat grooves)markings.Go figure The only time I use a bolt in overrunning clutch is if the stock one is bad.Having a bolt in one does not guarantee it won't break.
Re: bolt in sprag failure [Re: B G Racing] #272196
03/31/09 08:55 AM
03/31/09 08:55 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
What's interesting is that the LBA should have still held the drum, even after the one-way roller clutch failed.
Re: bolt in sprag failure [Re: dizuster] #272197
03/31/09 09:39 AM
03/31/09 09:39 AM
Indiana
65dragnet Offline
65dragnet  Offline
Indiana
evidently the LBA and the steel drum did their job ! He didn't mention any broken or torn up feet. Sprags tranny's or engines are not indestuctable
E. Williams 65 Coronet 500 3400lbs w/d, 446, Indy EZ'S, A&A transbrake,Comp 650 lift cam, 6.50 @ 105 mph 1/8th 10.25 @ 130mph 1/4
Re: bolt in sprag failure [Re: rebel] #272198
03/31/09 12:41 PM
03/31/09 12:41 PM
NC
440Jim Offline
440Jim  Offline
NC
This makes me think other things got broke, and your disassembly confirms it. If only the sprage wasn't holding, shifting to 2nd should have been OK. Also the LBA
Re: bolt in sprag failure [Re: rebel] #272199
03/31/09 12:53 PM
03/31/09 12:53 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Does the torque converter still hold at the same RPM
Re: bolt in sprag failure [Re: MR_P_BODY] #272200
04/01/09 12:42 AM
04/01/09 12:42 AM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
trans man tells me i've been off n on the pedal all the time but i'm not. he even says i shouldn't start the burnout in 2nd. i'm no john force on the burnout. i start in 2nd & as soon as i see smoke by the window i shift into 3rd & release the linelock & ease off the pedal. does that sound right? slicks still have depth dots @ the end of season so i'm not overkilling it. burnout limiter is set @ 6500 on a 5500 stall converter. when daughter gets home i'll take a pic & post it. it was a 4 bolt sprag.
Re: bolt in sprag failure [Re: rebel] #272201
04/01/09 01:21 AM
04/01/09 01:21 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I have been told the 12-element sprags (4-bolt) really are not any better than the stock one, and they were supposed to be a fix for sprags that were loose in the case?
I don't have any information on the valve body you are using, but a stock valve body will apply the low band when in manual low, but if you place the selector in 2nd or drive the trans starts in low/breakaway without the low band apply?
I have read some articles that alaways say to do your burnout in second gear, but this seemed to be when using a reverse manual valve body?
Re: bolt in sprag failure [Re: 451Mopar] #272202
04/01/09 02:22 AM
04/01/09 02:22 AM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
pics at last
Re: bolt in sprag failure [Re: rebel] #272203
04/01/09 02:23 AM
04/01/09 02:23 AM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
another
Re: bolt in sprag failure [Re: rebel] #272204
04/01/09 02:24 AM
04/01/09 02:24 AM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
the sprag. the rollers(not shown) all have flat spots on them????
Re: bolt in sprag failure [Re: rebel] #272205
04/01/09 07:12 AM
04/01/09 07:12 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
she sure rolled over - thats for sure!
Re: bolt in sprag failure [Re: rebel] #272206
04/01/09 12:51 PM
04/01/09 12:51 PM
A while a go there was discussion about doing a burnout in second. If you have a low horsepower car maybe but I have been doing a burnout in high gear only with no issues at all. I'm not say this is why you had a failure but you never know!
Re: bolt in sprag failure [Re: 451Mopar] #272207
04/01/09 12:56 PM
04/01/09 12:56 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
I guess I wasn't being a total dilweed when I bolted in the original one without taking it out. And once I had 4 bolts in, adding the other 2 wasn't much more work. So far so good.
Re: bolt in sprag failure [Re: rebel] #272208
04/01/09 03:37 PM
04/01/09 03:37 PM
Southington Ct.
Southington Ct.
Is it just me or does this thing look like it got hot ? Maybe lack of oil lub somehow? Is there any galling on the mainshaft or governor support(or whatever they call it)?
Allan G.
