New 4150 style Sniper EFI #2719626
11/27/19 01:29 AM
11/27/19 01:29 AM
AndyF Offline OP
AndyF  Offline OP
Got the new 4150 style Holley Sniper EFI setup today. Looks pretty good. It has a standard throttle linkage and dual fuel inlet so it should fit a lot of applications without mods.
Re: New 4150 style Sniper EFI [Re: AndyF] #2719650
11/27/19 07:49 AM
11/27/19 07:49 AM
Northern Bavaria / Germany
MichaelF Offline
MichaelF  Offline
cool, i like the radiused entry better than the design before. They even put in the float adjusting screws....looks nice. Anything else different to the existing sniper 650?
Michael
Re: New 4150 style Sniper EFI [Re: MichaelF] #2719653
11/27/19 08:44 AM
11/27/19 08:44 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
How does the "carb style" effect the cost? IMO this is the way they should have come to market with the sniper. It looks really good which is hurdle that lots of people couldn't overcome about the throttle body systems.
68 Barracuda Formula S 340
Re: New 4150 style Sniper EFI [Re: AndyF] #2719664
11/27/19 09:37 AM
11/27/19 09:37 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
HP capabilities?
Re: New 4150 style Sniper EFI [Re: Bad340fish] #2719676
11/27/19 10:25 AM
11/27/19 10:25 AM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
Originally Posted by Bad340fish
IMO this is the way they should have to market with the sniper. It looks really good which is hurdle that lots of people couldn't overcome about the throttle body systems.
Agreed! I would have preferred mine to look like a 4150 instead of a weird, anodized Thermoquad pancake looking thing! rant
'71 Duster
'72 Challenger
'17 Ram 1500
Re: New 4150 style Sniper EFI [Re: BradH] #2719732
11/27/19 01:28 PM
11/27/19 01:28 PM
BradH Offline
BradH  Offline
Originally Posted by BradH
HP capabilities?
Holley says 870 CFM; 650 HP NA with 4 100# injectors.
It would be interesting if they come out with a bigger 4150 Stealth model. I like this style better than the original Sniper design, although I don't know if they're functionally equivalent.
Is that a 1-to-1 linkage, or progressive?
Re: New 4150 style Sniper EFI [Re: BradH] #2719734
11/27/19 01:32 PM
11/27/19 01:32 PM
AndyF Offline OP
AndyF  Offline OP
I would expect that they'll release a version with the 120 lb/hr injectors which is what you would need for your engine. I don't have any inside info but it just makes sense for them to do that. The linkage is 1:1 out of the box. It can be changed over to progressive but then the unit has to be reprogrammed. I run mine in 1:1 mode. I tried progressive but decided to go back to 1:1 linkage.
Re: New 4150 style Sniper EFI [Re: AndyF] #2719782
11/27/19 03:40 PM
11/27/19 03:40 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Do most of these bolt on FI units still have issues with large cams that produce low vacuum?
Re: New 4150 style Sniper EFI [Re: justinp61] #2719785
11/27/19 03:47 PM
11/27/19 03:47 PM
AndyF Offline OP
AndyF  Offline OP
Just depends on how low the vacuum is. If vacuum at idle is really low then you have to run open loop at idle and go closed loop at 1500 or 2000 rpm. The Sniper doesn't have any problem handling race cams or even open headers but you have to adjust the tune. The out of the box tune won't work. If you know what you're doing it only takes a few minutes to dial in the tune. If you don't know what you're doing then it could take much longer.
Re: New 4150 style Sniper EFI [Re: AndyF] #2719828
11/27/19 06:02 PM
11/27/19 06:02 PM
BradH Offline
BradH  Offline
I'm trying to imagine driving on the street, staging, and launching off a foot-brake using a 1-to-1 linkage...
Re: New 4150 style Sniper EFI [Re: AndyF] #2719839
11/27/19 06:47 PM
11/27/19 06:47 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I'd be in the second category. LOL
Re: New 4150 style Sniper EFI [Re: BradH] #2719842
11/27/19 07:01 PM
11/27/19 07:01 PM
Washington
madscientist Offline
Washington
I used to convert all my carbs to 1:1 linkage. The one I'm using now isn't, but it's just a linkage adjustment.
And soon, it will be 1:1 as well, I just need to do some other stuff first.
Re: New 4150 style Sniper EFI [Re: madscientist] #2720761
12/01/19 08:01 PM
12/01/19 08:01 PM
The Wet Coast, Canada
megajoltman Offline
megajoltman  Offline
They now have HOLLEY SUPER SNIPER STEALTH 4150 - 1250HP one on there site. up
1969 Dart 383/727/D60
CTD Ram 4x4 Mega Cab
Procharged 350Z
Re: New 4150 style Sniper EFI [Re: BradH] #2720773
12/01/19 08:45 PM
12/01/19 08:45 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I recently programmed a tune for my friends Charger with the non-stealth style of Sniper on a 446 with a 6 speed.
The one-to-one linkage was a non-issue driving the car around in traffic with his combo.
Re: New 4150 style Sniper EFI [Re: megajoltman] #2720784
12/01/19 09:35 PM
12/01/19 09:35 PM
BradH Offline
BradH  Offline
Not for naturally aspirated; that's still limited to a claimed 650 HP. Probably sometime, though.
Re: New 4150 style Sniper EFI [Re: BradH] #2720794
12/01/19 10:23 PM
12/01/19 10:23 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
This is NA 4150 800 hp
Re: New 4150 style Sniper EFI [Re: fast68plymouth] #2720802
12/01/19 10:56 PM
12/01/19 10:56 PM
AndyF Offline OP
AndyF  Offline OP
Yeah the 1:1 ratio setup works fine in my car too. Maybe a tiny bit too sensitive right off idle but that is it. Holley does sell a longer throttle arm which slows down the speed of the throttle opening so that can be tried. I like the 1:1 setup in terms of how the mixture gets pointed into the intake. I've had trouble with the progressive linkage on a Sniper with the mixture being pushed to the front of the intake at part throttle.
I do not have any experience with the 1:1 linkage and a two step. I'm sure people are doing it but I haven't talked to anyone who runs that setup.
