Re: New 4150 style Sniper EFI
[Re: MichaelF]
#2719653
11/27/19 08:44 AM
11/27/19 08:44 AM
Posts: 8,030 Tulsa OK
Bad340fish
Tulsa OK
How does the "carb style" effect the cost? IMO this is the way they should have come to market with the sniper. It looks really good which is hurdle that lots of people couldn't overcome about the throttle body systems.
68 Barracuda Formula S 340
[Re: Bad340fish]
#2719676
11/27/19 10:25 AM
11/27/19 10:25 AM
Posts: 1,894 Spahn Ranch
RMCHRGR
Spahn Ranch
IMO this is the way they should have to market with the sniper. It looks really good which is hurdle that lots of people couldn't overcome about the throttle body systems. Agreed! I would have preferred mine to look like a 4150 instead of a weird, anodized Thermoquad pancake looking thing!
'71 Duster '72 Challenger '17 Ram 1500
[Re: BradH]
#2719732
11/27/19 01:28 PM
11/27/19 01:28 PM
BradH
Holley says 870 CFM; 650 HP NA with 4 100# injectors. It would be interesting if they come out with a bigger 4150 Stealth model. I like this style better than the original Sniper design, although I don't know if they're functionally equivalent. Is that a 1-to-1 linkage, or progressive?
[Re: justinp61]
#2719785
11/27/19 03:47 PM
11/27/19 03:47 PM
Posts: 31,056 Oregon
AndyF
Do most of these bolt on FI units still have issues with large cams that produce low vacuum? Just depends on how low the vacuum is. If vacuum at idle is really low then you have to run open loop at idle and go closed loop at 1500 or 2000 rpm. The Sniper doesn't have any problem handling race cams or even open headers but you have to adjust the tune. The out of the box tune won't work. If you know what you're doing it only takes a few minutes to dial in the tune. If you don't know what you're doing then it could take much longer.
[Re: AndyF]
#2719828
11/27/19 06:02 PM
11/27/19 06:02 PM
BradH
I would expect that they'll release a version with the 120 lb/hr injectors which is what you would need for your engine. I don't have any inside info but it just makes sense for them to do that. The linkage is 1:1 out of the box. It can be changed over to progressive but then the unit has to be reprogrammed. I run mine in 1:1 mode. I tried progressive but decided to go back to 1:1 linkage. I'm trying to imagine driving on the street, staging, and launching off a foot-brake using a 1-to-1 linkage...
[Re: AndyF]
#2719839
11/27/19 06:47 PM
11/27/19 06:47 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
Do most of these bolt on FI units still have issues with large cams that produce low vacuum? Just depends on how low the vacuum is. If vacuum at idle is really low then you have to run open loop at idle and go closed loop at 1500 or 2000 rpm. The Sniper doesn't have any problem handling race cams or even open headers but you have to adjust the tune. The out of the box tune won't work. If you know what you're doing it only takes a few minutes to dial in the tune. If you don't know what you're doing then it could take much longer. I'd be in the second category. LOL
[Re: BradH]
#2719842
11/27/19 07:01 PM
11/27/19 07:01 PM
Posts: 4,457 Washington
madscientist
Washington
I would expect that they'll release a version with the 120 lb/hr injectors which is what you would need for your engine. I don't have any inside info but it just makes sense for them to do that. The linkage is 1:1 out of the box. It can be changed over to progressive but then the unit has to be reprogrammed. I run mine in 1:1 mode. I tried progressive but decided to go back to 1:1 linkage. I'm trying to imagine driving on the street, staging, and launching off a foot-brake using a 1-to-1 linkage... I used to convert all my carbs to 1:1 linkage. The one I'm using now isn't, but it's just a linkage adjustment. And soon, it will be 1:1 as well, I just need to do some other stuff first.
[Re: BradH]
#2720773
12/01/19 08:45 PM
12/01/19 08:45 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I would expect that they'll release a version with the 120 lb/hr injectors which is what you would need for your engine. I don't have any inside info but it just makes sense for them to do that. The linkage is 1:1 out of the box. It can be changed over to progressive but then the unit has to be reprogrammed. I run mine in 1:1 mode. I tried progressive but decided to go back to 1:1 linkage. I'm trying to imagine driving on the street, staging, and launching off a foot-brake using a 1-to-1 linkage... I recently programmed a tune for my friends Charger with the non-stealth style of Sniper on a 446 with a 6 speed. The one-to-one linkage was a non-issue driving the car around in traffic with his combo.
