727 Valve Body #2718918
11/24/19 04:07 PM
11/24/19 04:07 PM
ontario canada
426lloyd Offline OP
426lloyd  Offline OP
ontario canada
Will a later valve body ( non lockup ) work in a 1966 727 , thanks
Re: 727 Valve Body [Re: 426lloyd] #2718932
11/24/19 05:27 PM
11/24/19 05:27 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Up to '70 will work properly, '71-later will fit and function but it won't work properly due to changes in the accumulator configuration.
Re: 727 Valve Body [Re: John_Kunkel] #2718991
11/24/19 08:12 PM
11/24/19 08:12 PM
ontario canada
426lloyd Offline OP
426lloyd  Offline OP
ontario canada
Ok, can I take a 1979 case and put all the internals from a 1966 case into it .
Re: 727 Valve Body [Re: 426lloyd] #2719146
11/25/19 12:46 PM
11/25/19 12:46 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Everything but the VB; again, the configuration of the accumulator limits VB interchangeability.
Re: 727 Valve Body [Re: John_Kunkel] #2719166
11/25/19 01:46 PM
11/25/19 01:46 PM
ontario canada
426lloyd Offline OP
426lloyd  Offline OP
ontario canada
Ok thanks , I will put all the 66 parts into the 79 case and use the later vb.
