Throwout bearing slop on input shaft #2715977
11/14/19 11:55 PM
11/14/19 11:55 PM
Central US
grancuda Offline OP
grancuda  Offline OP
Central US
Picked up a ‘75 Ramcharger & trying to diagnose an occasionally shaky clutch pedal when it’s depressed. The Z bar is floppy on the ball stud but there is no spring on the clutch fork but the most issue I think I have is the up & down movement of the throwout bearing on the shaft. Is there suppose to me that much room for movement in the throwout bearing or should the throwout bearing have had a smaller inside diameter? Or does the spring on the fork keep slight pressure to keep it in the right spot?
https://youtu.be/l8BFz8sfBnQ
1967 Barracuda Formula S 383
1967 Chevy C10 Short Stepper
1980 Macho Power Wagon LWB 318
2021 Toyota Supra
Re: Throwout bearing slop on input shaft [Re: grancuda] #2715980
11/15/19 12:15 AM
11/15/19 12:15 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Looks way too loose.
Re: Throwout bearing slop on input shaft [Re: grancuda] #2716096
11/15/19 01:22 PM
11/15/19 01:22 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The video looks like it might be a Hemi TO bearing on a non-Hemi shaft. I recently got a clutch kit from Autozone that had a plastic TO bearing sleeve, fit real loose...I didn't use it.
Re: Throwout bearing slop on input shaft [Re: John_Kunkel] #2716321
11/16/19 10:39 AM
11/16/19 10:39 AM
Central US
grancuda Offline OP
grancuda  Offline OP
Central US
That would make the most sense. Everything has been overdone on this Ramcharger on the engine. Low compression 318 with a 750 Holley, Edelbrock performer intake, MSD pro billet distributor, MSD 6AL, Centerforce dual friction & Centerforce flywheel. So I’m sure they heard “Hemi throwout bearing” & figured it’s “got to be better” so I need it.
2021 Toyota Supra
Re: Throwout bearing slop on input shaft [Re: grancuda] #2716324
11/16/19 10:47 AM
11/16/19 10:47 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
non Hemi TO Bearing Assembly; Bore=1.2525"
Hemi TO Bearing Assembly; Bore=1.422"
Re: Throwout bearing slop on input shaft [Re: Sniper] #2716452
11/16/19 04:07 PM
11/16/19 04:07 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
A few other parts store clutch kits come with that plastic throw out bearing retainer as well. I installed one on a V6 Dakota a guy brought me once. 3 weeks later I got to replace he plastic throw out bearing. The parts store replaced the entire clutch kit and didn't want the old one back. So I have had a new in the box clutch disc and pressure plate sitting here for about 3 years now.
Its also possible the input shaft front bearing collar is worn as well, this stuff isn't getting any newer. Gene
