Throwout bearing slop on input shaft
#2715977
11/14/19 11:55 PM
11/14/19 11:55 PM
Posts: 1,009 Central US
grancuda
Central US
Picked up a ‘75 Ramcharger & trying to diagnose an occasionally shaky clutch pedal when it’s depressed. The Z bar is floppy on the ball stud but there is no spring on the clutch fork but the most issue I think I have is the up & down movement of the throwout bearing on the shaft. Is there suppose to me that much room for movement in the throwout bearing or should the throwout bearing have had a smaller inside diameter? Or does the spring on the fork keep slight pressure to keep it in the right spot? https://youtu.be/l8BFz8sfBnQ
1967 Barracuda Formula S 383 1967 Chevy C10 Short Stepper 1980 Macho Power Wagon LWB 318 2021 Toyota Supra
Re: Throwout bearing slop on input shaft
[Re: grancuda]
#2716096
11/15/19 01:22 PM
11/15/19 01:22 PM
Posts: 25,842 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The video looks like it might be a Hemi TO bearing on a non-Hemi shaft. I recently got a clutch kit from Autozone that had a plastic TO bearing sleeve, fit real loose...I didn't use it.
[Re: John_Kunkel]
#2716321
11/16/19 10:39 AM
11/16/19 10:39 AM
grancuda
Central US
The video looks like it might be a Hemi TO bearing on a non-Hemi shaft. That would make the most sense. Everything has been overdone on this Ramcharger on the engine. Low compression 318 with a 750 Holley, Edelbrock performer intake, MSD pro billet distributor, MSD 6AL, Centerforce dual friction & Centerforce flywheel. So I’m sure they heard “Hemi throwout bearing” & figured it’s “got to be better” so I need it.
