Question about Front Seat #271481
03/30/09 01:22 PM
03/30/09 01:22 PM
Kentucky, USA
RoadrunnerCN Offline OP
Kentucky, USA
I replaced the front seat in my 1970 Satellite with a split bench that came out of a 1969 Dodge Coronet. My question is this: I want to get new upholstery and was thinking of buying the Roadrunner design and put it on myself. However, I'm unsure if the 1970 Roadrunner split bench upholstery would fit the 1960 Dodge Coronet split bench. I'm betting it would but wondered if any of you knew if they were the same construction/size (I know the upholstery stitch pattern was different), just wonder about the size/contruction. Let me know. You guys have been great. Take care, Chris.
Re: Question about Front Seat [Re: RoadrunnerCN] #271482
03/30/09 01:31 PM
03/30/09 01:31 PM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
check with dante,bet he knows.good luck
Re: Question about Front Seat [Re: RoadrunnerCN] #271483
03/30/09 02:32 PM
03/30/09 02:32 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The lever that releases the seat back is in a different place starting in 70 , it's up on the side of the back instead of a lever on the bottom pivot arm , if the seat back material is not cut for that , which I don't think it will be, you should be able to use the 69 seat as everything else is basically the same . The headrest are also different , they used a headrest that looks like the 69 bucket seat headrest , but I'm pretty sure the post spacing is the same .
Re: Question about Front Seat [Re: JohnRR] #271484
03/30/09 03:33 PM
03/30/09 03:33 PM
Kentucky, USA
Kentucky, USA
Thanks, good information. Yes, the level is at the bottom where the back pivots and not on the side of the back. I appreciate the help. Chris.
