Shaft mounted valve spring compressor tools #2714586
11/10/19 05:30 PM
11/10/19 05:30 PM
Aurora, CO
jbeintherockies Offline OP
Aurora, CO
Hello,
I have a 340 with X heads and the shaft-mounted rocker assembly. I need to change some of the valve seals. I really do not want to remove the heads to do it.
What valve spring compressor tools do you guys use to compress the valve springs with the heads still bolted to the block for an LA engine?
Not sure what questions to ask or specifics to provide. Please ask for details if needed.
TYIA wrench
Re: Shaft mounted valve spring compressor tools [Re: jbeintherockies] #2714587
11/10/19 05:40 PM
11/10/19 05:40 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
The Proform 67460 work pretty well. Use compressed air or rope to hold the valves while compressing the spring.
https://www.summitracing.com/parts/pro-67460/
Re: Shaft mounted valve spring compressor tools [Re: John_Kunkel] #2714736
11/11/19 10:29 AM
11/11/19 10:29 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Quite a bit more expensive but worth it in my opinion. Easier to use when working by yourself.
https://www.summitracing.com/parts/lsm-sc-800/overview/
Re: Shaft mounted valve spring compressor tools [Re: 340Cuda] #2714740
11/11/19 10:34 AM
11/11/19 10:34 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Explain how that works on a shaft mounted rocker head?
Re: Shaft mounted valve spring compressor tools [Re: jbeintherockies] #2714774
11/11/19 12:21 PM
11/11/19 12:21 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Standard jaw type valve spring compressor and air the cylinder up is all you need....costs ya $25-$40 in tools
Re: Shaft mounted valve spring compressor tools [Re: jbeintherockies] #2714776
11/11/19 12:37 PM
11/11/19 12:37 PM
The one Mopar sells for SB works very well scope
Re: Shaft mounted valve spring compressor tools [Re: 340Cuda] #2714926
11/11/19 08:09 PM
11/11/19 08:09 PM
Aurora, CO
Aurora, CO
The SC-100 is the unit for the small block mopar. however, you need to buy the adapter plate (SC-146).
http://www.lsmproducts.com/lsm_tools/valve_spring_compressors
Between the two parts, you are at: $205.99 + $59.99 = $265.98. To use it, remove the rocker shaft assembly and bolt it to where the shaft assembly would normally bolt to. Then use the tool on one section of I/E at a time to compress the springs. The good thing about it, you can compress the spring and use both hands to install the retainer and locks.
This is cheaper, but may be more difficult to use with one hand while I use my other hand to install the retainer and locks.
https://www.manciniracing.com/en2pivaspto.html
Re: Shaft mounted valve spring compressor tools [Re: jbeintherockies] #2714928
11/11/19 08:20 PM
11/11/19 08:20 PM
The Pro Form unit looks a lot like the original Mopar brand, those units, both BB and Sb, worked very well up
Re: Shaft mounted valve spring compressor tools [Re: jbeintherockies] #2714941
11/11/19 08:41 PM
11/11/19 08:41 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
For $200 less you can slide a cheater pipe over the handle and hang a weight on it to keep the spring compressed and use two hands to do what you need to do.
Re: Shaft mounted valve spring compressor tools [Re: jbeintherockies] #2715333
11/13/19 05:31 AM
11/13/19 05:31 AM
Australia
Mcode69 Offline
Mcode69  Offline
Australia
Made this up from a few bits and pieces.
Re: Shaft mounted valve spring compressor tools [Re: Mcode69] #2715341
11/13/19 08:08 AM
11/13/19 08:08 AM
London, England
Gavin Offline
Gavin  Offline
London, England
That's pretty much what I did, I even used the stock shafts. That and some rope. Cost $0.
Re: Shaft mounted valve spring compressor tools [Re: Gavin] #2715344
11/13/19 08:42 AM
11/13/19 08:42 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
My son bough the one Summit sells.That was like 15 years ago.Works real nice even on heavy springs.It was fairly cheap then.Rocky
Chrysler Firepower
Re: Shaft mounted valve spring compressor tools [Re: Sniper] #2715419
11/13/19 01:04 PM
11/13/19 01:04 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
There is a plate that bolts on the head, the rocker shafts need to be removed. Mine was purchased for W9 heads but my son has used it on his W2 heads, he had to make a plate but LSM sells the plate now. The main advantage to me is that it holds the spring down on its own and you can use two hands to get keepers in, out and positioned correctly.
That all being said I would check with LSM to be sure they have something that will work with your heads.
All the LSM stuff that I have is top notch.
Re: Shaft mounted valve spring compressor tools [Re: 340Cuda] #2715476
11/13/19 05:12 PM
11/13/19 05:12 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I have the LSM for my engine but I don't know if they have one for small blocks but it's worth every penny.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Shaft mounted valve spring compressor tools [Re: jbeintherockies] #2715870
11/14/19 07:44 PM
11/14/19 07:44 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
Home made, less than $20
Re: Shaft mounted valve spring compressor tools [Re: R/T1968R/T] #2716218
11/15/19 08:15 PM
11/15/19 08:15 PM
God's Country Maryland
GODSCOUNTRY340 Offline
Another self made one.
