Max compression on methanol?
#2713527
11/06/19 09:42 PM
11/06/19 09:42 PM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
For a long time i believed the max compression for a normally s Aspirated motor should be 15 to 15.5 to1. BUT, it was pointed out to me that head limited motors can get away with a bit more because they can't fill the cylinders to the same high percent as a motor with excelent heads. My situation is i am increasing displacement from 528 to 560 cube, and if i don,t cut the domes some the compression will jump from 15.1 to about 16 to 1. 440-1 fully ported alky megablock. .870 gross lift cam, 3x intake and alky injection. Best 8.77 at 3055 weight. Thoughts?
Re: Max compression on methanol?
[Re: Twostick]
#2713543
11/06/19 10:42 PM
11/06/19 10:42 PM
gregsdart
Maybe on the better methanol although i don't know how they would do it. From what i know of methanol, above a certain cylinder pressure before ignition the mixture has to be richened to increase detonation resistance. The power loss of the very fat mixture is offset by higher boost.
[Re: greendart408]
#2713778
11/07/19 05:36 PM
11/07/19 05:36 PM
Posts: 2,652 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I'm sure Top Alcohol cars are over 50 lbs of boost. I don't know how to calculate that to compression ratio but I'm guessing it's way over 25:1.
2011 Drag Pak Challenger
[Re: rickseeman]
#2713808
11/07/19 07:20 PM
11/07/19 07:20 PM
gregsdart
Rick the tuning book i have says blown cars need a mixture of 3.7 to 4 or so to work with those extreme pressures. Normally aspirated equals 5.2 to 5.5. So i am thinking that at some po i n t in raising compression the overly rich mixture needed will cancel any power gains.
[Re: roadrunninMark]
#2715557
11/13/19 10:12 PM
11/13/19 10:12 PM
gregsdart
I could but i don't know what increasing quench distance will do. Plus the goal is to run as much compression as i can without shortening the life of the motor. Thicker gaskets also increase crevis volume which hurts performance from what i have read. The gaskets are 4.6 bore. So the plan is to run a .027 or .036 cometic and cut the dome which is .115 high and should give me enough to work with to bring it down to low 15 range. As is i suspect it will be about 16 to 1. I haven't had a chance to measure everything yet.
