Bypassing ballast resistor #2712074
11/02/19 11:47 AM
11/02/19 11:47 AM
14437
HOTHEMI Offline OP
HOTHEMI  Offline OP
14437
Whats the best way to bypass the ballast resistor using a factory harness in a 72 E-body without making it look like a hack job ? Thanks
Re: Bypassing ballast resistor [Re: HOTHEMI] #2712078
11/02/19 12:03 PM
11/02/19 12:03 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
This is a single ballast that I did
Scraping out the ceramic to expose the resistor took the longest
Your factory 1972 probably has the dual ballast resistor
But either way if you want to keep the factory look and everything original
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Bypassing ballast resistor [Re: bee1971] #2712168
11/02/19 06:12 PM
11/02/19 06:12 PM
14437
HOTHEMI Offline OP
HOTHEMI  Offline OP
14437
It does have a dual ballast, I'm not so concerned with keeping it looking stock, it's a new harness and want do it neatly as possible . Thanks
Re: Bypassing ballast resistor [Re: HOTHEMI] #2712346
11/03/19 11:11 AM
11/03/19 11:11 AM
Mequon, WI
gzig5 Offline
gzig5  Offline
Mequon, WI
I've got a 73 Cuda with the dual element. I bought a spare resistor online for $7 and carved it out for the jumper as shown when I went with the FBO module. You can't tell with it installed and I still have the original if I ever need to swap in the OEM controller as a backup. Probably can get one cheaper at a swap meet or junkyard but I was pressed for time.
