Re: Valve covers and spacers for roller rockers on 440
[Re: Larry]
#2710916
10/29/19 12:09 PM
10/29/19 12:09 PM
Posts: 5,443 Indiana
YO7_A66
Indiana
I used the Medice Manufacturing spacers on my 340 with both the iron heads and now with the aluminum heads. I started using them because I need more space over my 1.65 rocker arms while using the original style valve covers. I also found they fixed an oil leak that I was having after trying a handful of different valve cover gaskets. These spacers moved the valve cover up enough so that the gaskets (or sealing surface) were not setting in the oil puddle at the rear of the valve cover. They also gave my old valve covers something flat to seal against. Now I can use the cheapy cork gaskets with no leaks.
I did not paint my spacers but I have thought about it to make the spacers blend in a little more with the valve cover. But with the aluminum heads it would not have made as much of a difference than it would if I was still running the old iron heads.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: Larry]
#2711247
10/30/19 01:40 PM
10/30/19 01:40 PM
Posts: 20,179 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I bought two sets for my small blocks because when using the better high port intake manifolds the valve covers sat on the intake runners causing bad leaks. I just used black silicone to glue them on my heads then used baskets on top for easy removal
[Re: Larry]
#2711855
11/01/19 11:50 AM
11/01/19 11:50 AM
Posts: 523 Right here
HP2
Right here
Does anyone have any experience using the Medice Manufacturing spacers with stock (OEM or AMD) valve covers, when trying to clear roller rockers (Harland Sharp in my case)? I am using Performer RPM heads. I see so many threads about leaks, that I am concerned that this just adds to the potential. I am hoping for something that looks stock or stockish.
I can't seem to convince myself that the Edelbrock Classic Series that I have now are the look I want. I welcome opinions on how to get closer to original looking, yet clear the rockers, and not leak.
Thanks A few whacks with a hammer took care of spacing on my original 1970 440 valve covers LOL. 1.6 Harland Sharp with .610/.614 lift cam
70 W100 Power Wagon. 318 4-spd 70 Sport Fury 440 2dr HT 71 Duster 340 71 Charger Super Bee - 383/727 72 Charger "Sabotage" - 440/727 - Street/Strip 78 Warlock in beautiful patina
[Re: Larry]
#2711876
11/01/19 12:26 PM
11/01/19 12:26 PM
Posts: 128 Troy,MI
Siba
Troy,MI
Fixing leaks rather than causing them is a bonus LOL. I was worried about having to double up the gaskets. My Performer RPM Heads are painted orange (with the logos shaved). If the AMD 1970 BB covers are not crap, I might have to go that route. I have only managed to find one real 70 cover yet!!! Has anyone recently installed the recent AMD's, versus the early runs, which I don't think got good reviews (unless it wasn't the 1970 version)?
Larry Good timing on this post, I need to do the same on my 440. I may have a set of original valve covers for sale if you are interested? Pm me if so.
