Re: 1969 Road Runner project
[Re: AndyF]
#2711498
10/31/19 07:13 AM
10/31/19 07:13 AM
Posts: 10,032 MN
JERICOGTX
MN
Stock 4 speed? If so, and it hooks, it's not going to last long with 700hp. Need more pictures!
69 GTX
68 Road Runner
[Re: jughed]
#2711553
10/31/19 10:51 AM
10/31/19 10:51 AM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
I hope he uses a McLeod RST clutch or something like that! Cool car! I love RR's.
[Re: AndyF]
#2711558
10/31/19 10:54 AM
10/31/19 10:54 AM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
The new engine has been dyno tested and is ready to go. It is a pump gas 508 with TF 270 heads and a Comp street roller. Made 700 hp with a Sniper XFlow on a ported intake. Should be fun. Car is a four speed with a Dana 60 so we'll see how long the transmission lasts. I would think he went with a roller cam not sft and if so what springs and psi are they?
[Re: jughed]
#2711584
10/31/19 11:41 AM
10/31/19 11:41 AM
Posts: 31,045 Oregon
AndyF
Stock 4 speed? If so, and it hooks, it's not going to last long with 700hp. Need more pictures! ....and now would the time to move the brake and (way too small) fuel lines. He is planning to install a 3/8 fuel line. Brake lines will be replaced with reproductions but not moved. It isn't a race car, just a street car with a bunch of power.
[Re: Clanton]
#2711588
10/31/19 11:43 AM
10/31/19 11:43 AM
AndyF
The new engine has been dyno tested and is ready to go. It is a pump gas 508 with TF 270 heads and a Comp street roller. Made 700 hp with a Sniper XFlow on a ported intake. Should be fun. Car is a four speed with a Dana 60 so we'll see how long the transmission lasts. I would think he went with a roller cam not sft and if so what springs and psi are they? He does have a Comp street roller cam. 260/266 at 050. The springs are dual conical with T&D rocker arms.
[Re: AndyF]
#2711596
10/31/19 12:39 PM
10/31/19 12:39 PM
Posts: 10,032 MN
JERICOGTX
MN
Andy, do you have any experience with Comps roller rockers? Not the aluminum ones.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2711675
10/31/19 05:01 PM
10/31/19 05:01 PM
AndyF
Andy, do you have any experience with Comps roller rockers? Not the aluminum ones. Yes I've used them on several engines over the years. They seem to work just fine for street or street/strip type of engine.
[Re: AndyF]
#2711705
10/31/19 07:24 PM
10/31/19 07:24 PM
Posts: 4,207 New York
polyspheric
New York
Ideal time to examine the "what oil pan clears what cross member?" question.
Boffin Emeritus
