Re: Victor head intame choices
[Re: Jeff_383]
#2707539
10/17/19 09:44 AM
10/17/19 09:44 AM
Posts: 14,499 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
You use any intake that matches the port size(std or MW) of the heads and deck height of the motor.
[Re: Jeff_383]
#2707541
10/17/19 09:49 AM
10/17/19 09:49 AM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
I put a factory iron on mine and it fit but was still not low enough to get the factory hood back on so I went back to a Victor 440 on an RB engine.
[Re: Jeff_383]
#2710250
10/26/19 08:35 PM
10/26/19 08:35 PM
Clanton
northern,Ohio,USA
Even with a drop base it wouldn't fit? I just tried with no filter.I used clay to check the gap about 1" and once the rpm's got around 5k it went rich to 10/1 a/f.I ran it 1st without a hood with no trouble. I could mill the choke horn but I don't want to mess with the tuneup.
