Victor head intame choices #2707530
10/17/19 09:23 AM
10/17/19 09:23 AM
Pittsburgh, Pa
Jeff_383 Offline OP
Jeff_383  Offline OP
Pittsburgh, Pa
Do the Victor heads require only a Victor intake? Or can any be used?
Re: Victor head intame choices [Re: Jeff_383] #2707539
10/17/19 09:44 AM
10/17/19 09:44 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
You use any intake that matches the port size(std or MW) of the heads and deck height of the motor.
Re: Victor head intame choices [Re: Jeff_383] #2707541
10/17/19 09:49 AM
10/17/19 09:49 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I put a factory iron on mine and it fit but was still not low enough to get the factory hood back on so I went back to a Victor 440 on an RB engine.
Re: Victor head intame choices [Re: Clanton] #2710248
10/26/19 08:23 PM
10/26/19 08:23 PM
Pittsburgh, Pa
Jeff_383 Offline OP
Jeff_383  Offline OP
Pittsburgh, Pa
Even with a drop base it wouldn't fit?
Re: Victor head intame choices [Re: Jeff_383] #2710250
10/26/19 08:35 PM
10/26/19 08:35 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I just tried with no filter.I used clay to check the gap about 1" and once the rpm's got around 5k it went rich to 10/1 a/f.I ran it 1st without a hood with no trouble.
I could mill the choke horn but I don't want to mess with the tuneup.
