91 W-350 Bellhousing PN. #2703042
10/02/19 01:25 PM
10/02/19 01:25 PM
McGregor,Iowa 52157
500ciDuster Offline OP
McGregor,Iowa 52157
Was wondering what the part number is?
Mitch
Re: 91 W-350 Bellhousing PN. [Re: 500ciDuster] #2703159
10/02/19 06:23 PM
10/02/19 06:23 PM
illinois
rbkt65 Offline
rbkt65  Offline
illinois
check on mopar parts giant.
Re: 91 W-350 Bellhousing PN. [Re: rbkt65] #2703559
10/03/19 07:27 PM
10/03/19 07:27 PM
McGregor,Iowa 52157
McGregor,Iowa 52157
Thanx
Re: 91 W-350 Bellhousing PN. [Re: 500ciDuster] #2703604
10/03/19 09:44 PM
10/03/19 09:44 PM
illinois
rbkt65 Offline
rbkt65  Offline
illinois
10 3/8 clutch w/ a535,a435/833 part number is 4471829
Re: 91 W-350 Bellhousing PN. [Re: rbkt65] #2704114
10/05/19 01:59 PM
10/05/19 01:59 PM
McGregor,Iowa 52157
McGregor,Iowa 52157
Is that the biggest clutch that they offered?
Re: 91 W-350 Bellhousing PN. [Re: 500ciDuster] #2705102
10/09/19 10:16 AM
10/09/19 10:16 AM
scratchnfotraction Offline
what trans?
in my 85 stepside I have a 93 D350 NV4500 5.9 magnum gas engine bell/use a 19 spline 11" clutch disc /the bell is nv4500 specific and hydro clutch.
IIRC the W350 nv4500 uses same bell and course 10 spline clutch disc gas or diesel? and can be 12"
my other hydro clutch bell is from a 88 v-6 d100 and had a a535 5 speed..it fits the a535/833/833OD/435 4 speeds
I also have a 12" clutch mech bell from a d/w350
if you are a 435 4 speed 4x4 the smaller hydro clutch bell works in the 91 with hydro clutch set up.
all on the shelf if you want part #s for all of them.
Re: 91 W-350 Bellhousing PN. [Re: scratchnfotraction] #2705108
10/09/19 10:31 AM
10/09/19 10:31 AM
McGregor,Iowa 52157
McGregor,Iowa 52157
I'm going to take this one off and check the number, just wanted to put the same one back on & am putting the NP 435 back in
