Has anyone ever seen a defect like this??? #2700877
09/25/19 05:54 PM
09/25/19 05:54 PM
Great Neck,LI,new york
hemi-itis Offline OP
I installed new M/T racing tubes on Friday and drove 70/80 miles R/T to Brooklyn.When I pulled into the garage and got out of the car I noticed the rear tire was half flat work Jacked up that wheel and left. Went back in the morning and aired it up to find the leak.Finally found a small spot making bubbles so I marked it up with a yellow crayon and removed the wheel and broke it down and pulled the tube. eek I have NEVER seen this type of defect,,,,have you??
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Has anyone ever seen a defect like this??? [Re: hemi-itis] #2700903
09/25/19 07:13 PM
09/25/19 07:13 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
That's not a defect.
You ripped the tube. It spun on the rim.
Bead locks dont take tubes.
Re: Has anyone ever seen a defect like this??? [Re: hemi-itis] #2700904
09/25/19 07:15 PM
09/25/19 07:15 PM
New Jersey, USA
Y
yella71 Offline
yella71  Offline
Y
New Jersey, USA
valve stem separated from the tube? yes I have seen that . I have fixed a lot of truck tires with tubes in them . The tube most likely spun and tore it off.
71 challenger convertable, 64 sport fury 383 ci with factory air 99 sebring convertable 89 CTD pup
Re: Has anyone ever seen a defect like this??? [Re: yella71] #2700909
09/25/19 07:24 PM
09/25/19 07:24 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
What they said. Pretty common torn off from incorrect install or caught the tire and moved
Re: Has anyone ever seen a defect like this??? [Re: Al_Alguire] #2700926
09/25/19 08:31 PM
09/25/19 08:31 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Same thing on mine exactly. Been.running tubes with no rim screws for about a year. Tire went flat. I aired it up and it didn't loose any air. On the burnout it shook BAD. After that it wouldn't hold air. Took it apart, same result as yours. Tires are now screwed to the rims.
Doug
Re: Has anyone ever seen a defect like this??? [Re: Sammy] #2701049
09/26/19 09:41 AM
09/26/19 09:41 AM
How would a double beadlock spin on the rim?? I was under the understanding that the dbl BL was better than rim screws work
I just called M/T. The tire is a tube type tire and with the dbl beadlock the tire will not move. I'm confident the tube was installed properly but ,,,,,,,hey,,anything is possible.
Re: Has anyone ever seen a defect like this??? [Re: hemi-itis] #2701053
09/26/19 09:55 AM
09/26/19 09:55 AM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
I have seen it, but find it hard to believe the tire spun with double bead lock. They are just glued to the tube. I would clean the bead real well and try again. Mark the rim and tire to see if it is spinning.
best of 11.24 at 119 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: Has anyone ever seen a defect like this??? [Re: FurryStump] #2701077
09/26/19 11:01 AM
09/26/19 11:01 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
If the tire didn't spin on the rim, perhaps the tire wrinkled/stretched enough on the hit to pull the tube. If the stem held, something has to give. shruggy
Kevin
Re: Has anyone ever seen a defect like this??? [Re: Twostick] #2701118
09/26/19 12:27 PM
09/26/19 12:27 PM
moparx Offline
moparx  Offline
saw that many times back in my teenage years working part time at the tire shop that was exactly 1/4 mile from my house.
both drag racers and dirt burners. also truck tubes.
now days, i have seen that frequently on these cheap-o chinesium hand carts ! instead of a "patch" being ripped off, the tube is "bonded" to the valve stem, and the stem pulls OUT of the tube.
hard to believe something like this happens, eh ? biggrin
beer
Re: Has anyone ever seen a defect like this??? [Re: moparx] #2701372
09/27/19 11:26 AM
09/27/19 11:26 AM
Florida STAYcation
dOc ! Online penguin-006
The village idiot's idiot
dOc !  Online Penguin-006
Florida STAYcation
beer
MopX ... when you were a teenager all they had were WOODEN WHEELS ! grin
Re: Has anyone ever seen a defect like this??? [Re: dOc !] #2701373
09/27/19 11:28 AM
09/27/19 11:28 AM
Florida STAYcation
Florida STAYcation
And to that jsta apimp OP .... an old guy like you - you shoulda had your TUBES TIED years ago ! grin
Re: Has anyone ever seen a defect like this??? [Re: hemi-itis] #2701426
09/27/19 02:34 PM
09/27/19 02:34 PM
That is not a defect, that is a failure from abuse work
Re: Has anyone ever seen a defect like this??? [Re: Cab_Burge] #2701446
09/27/19 03:50 PM
09/27/19 03:50 PM
montana
BANDIT Offline
BANDIT  Offline
montana
Need to watch the Tim McAmis video on beadlock mounting and checking. Have seen what he talks about.
64 Dodge Coronet 440. In progress
1998. Dodge Avenger. 8.35@165. 4400 DA
250” Neil and Parks Slip Joint. 7.36@183.
4600 DA
242" Mullis Dragster. 6.90@ 200mph
Re: Has anyone ever seen a defect like this??? [Re: Cab_Burge] #2701604
09/28/19 12:33 AM
09/28/19 12:33 AM
Cab,I installed them on Friday and drove to a car show,no real abuse!! I may have jumped on it........a little. whistling
Re: Has anyone ever seen a defect like this??? [Re: hemi-itis] #2701695
09/28/19 11:46 AM
09/28/19 11:46 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
You may have put the tube in upside down. They go in only one way and the other could cause this. You absolutely can use tubes with beadlock wheels. There is a correct way to install and when you get a new tube follow the directions that come with it to the letter.
Re: Has anyone ever seen a defect like this??? [Re: dOc !] #2701712
09/28/19 12:22 PM
09/28/19 12:22 PM
moparx Offline
moparx  Offline
wood wheels ? that may be the reason when i spun them REAL hard, they burst into flames............
beer
Re: Has anyone ever seen a defect like this??? [Re: moparx] #2701869
09/28/19 10:54 PM
09/28/19 10:54 PM
I will say the tube stem went in 1st and the tube stuffed into the rim,Than with out out the ring attached the tube is inflated with baby powder,enough for a newborn to last a week laugh2
You now check the tube you watched infated to verify tube intall is smooth,,unraveled with no twists.Deflate,,,,install ring and bring to pressure.
Re: Has anyone ever seen a defect like this??? [Re: hemi-itis] #2701986
09/29/19 01:34 PM
09/29/19 01:34 PM
I was taught back a lot of years ago in a service station when mounting tires with tubes to always inflate the tube so it has around 10.Lbs. of pressure and let it go completely flat at least once to get the wrinkles out of the tube before final inflation to the pressures wanted up wrench
On all the race tubes I do that at least twice to insure no wrinkles after finding one 9x30 race tube in my old stocker with bad wrinkle in it when installing new tires, luckily it didn't ruin the tube boogie
Re: Has anyone ever seen a defect like this??? [Re: Cab_Burge] #2702122
09/29/19 10:30 PM
09/29/19 10:30 PM
Aired up the 1st time with the BL ring off and had my hand around the whole tube checking for anything abnormal,deflated and aired up to 10 lbs.Deflated to install on the car and set it at 12 lbs.It's good now!
