Has anyone ever seen a defect like this???
#2700877
09/25/19 05:54 PM
09/25/19 05:54 PM
Posts: 12,588 Great Neck,LI,new york
hemi-itis
I installed new M/T racing tubes on Friday and drove 70/80 miles R/T to Brooklyn.When I pulled into the garage and got out of the car I noticed the rear tire was half flat Jacked up that wheel and left. Went back in the morning and aired it up to find the leak.Finally found a small spot making bubbles so I marked it up with a yellow crayon and removed the wheel and broke it down and pulled the tube. I have NEVER seen this type of defect,,,,have you??
Re: Has anyone ever seen a defect like this???
[Re: hemi-itis]
#2700904
09/25/19 07:15 PM
09/25/19 07:15 PM
Posts: 1,406 New Jersey, USA
yella71
New Jersey, USA
valve stem separated from the tube? yes I have seen that . I have fixed a lot of truck tires with tubes in them . The tube most likely spun and tore it off.
71 challenger convertable, 64 sport fury 383 ci with factory air
99 sebring convertable
89 CTD pup
[Re: yella71]
#2700909
09/25/19 07:24 PM
09/25/19 07:24 PM
Posts: 19,373 Las Vegas
Al_Alguire
Las Vegas
What they said. Pretty common torn off from incorrect install or caught the tire and moved
[Re: Sammy]
#2701049
09/26/19 09:41 AM
09/26/19 09:41 AM
hemi-itis
That's not a defect. You ripped the tube. It spun on the rim. Bead locks dont take tubes. How would a double beadlock spin on the rim?? I was under the understanding that the dbl BL was better than rim screws I just called M/T. The tire is a tube type tire and with the dbl beadlock the tire will not move. I'm confident the tube was installed properly but ,,,,,,,hey,,anything is possible.
[Re: hemi-itis]
#2701053
09/26/19 09:55 AM
09/26/19 09:55 AM
Posts: 2,833 Connecticut
FurryStump
Connecticut
I have seen it, but find it hard to believe the tire spun with double bead lock. They are just glued to the tube. I would clean the bead real well and try again. Mark the rim and tire to see if it is spinning.
[Re: Twostick]
#2701118
09/26/19 12:27 PM
09/26/19 12:27 PM
Posts: 19,470 north of coder
moparx
saw that many times back in my teenage years working part time at the tire shop that was exactly 1/4 mile from my house. both drag racers and dirt burners. also truck tubes. now days, i have seen that frequently on these cheap-o chinesium hand carts ! instead of a "patch" being ripped off, the tube is "bonded" to the valve stem, and the stem pulls OUT of the tube. hard to believe something like this happens, eh ?
[Re: moparx]
#2701372
09/27/19 11:26 AM
09/27/19 11:26 AM
Posts: 30,451 Florida STAYcation
dOoC
The village idiot's idiot
Florida STAYcation
saw that many times back in my teenage years working part time at the tire shop that was exactly 1/4 mile from my house. both drag racers and dirt burners. also truck tubes. now days, i have seen that frequently on these cheap-o chinesium hand carts ! instead of a "patch" being ripped off, the tube is "bonded" to the valve stem, and the stem pulls OUT of the tube. hard to believe something like this happens, eh ? MopX ... when you were a teenager all they had were WOODEN WHEELS !
[Re: Cab_Burge]
#2701446
09/27/19 03:50 PM
09/27/19 03:50 PM
Posts: 422 montana
BANDIT
montana
Need to watch the Tim McAmis video on beadlock mounting and checking. Have seen what he talks about.
64 Dodge Coronet 440. In progress 1998. Dodge Avenger. 8.35@165. 4400 DA 250” Neil and Parks Slip Joint. 7.36@183. 4600 DA 242" Mullis Dragster. 6.90@ 200mph
[Re: moparx]
#2701869
09/28/19 10:54 PM
09/28/19 10:54 PM
hemi-itis
I will say the tube stem went in 1st and the tube stuffed into the rim,Than with out out the ring attached the tube is inflated with baby powder,enough for a newborn to last a week You now check the tube you watched infated to verify tube intall is smooth,,unraveled with no twists.Deflate,,,,install ring and bring to pressure.
[Re: Cab_Burge]
#2702122
09/29/19 10:30 PM
09/29/19 10:30 PM
hemi-itis
Aired up the 1st time with the BL ring off and had my hand around the whole tube checking for anything abnormal,deflated and aired up to 10 lbs.Deflated to install on the car and set it at 12 lbs.It's good now!
