Page 1 of 3 1 2 3
Hemi Cuda.....1st Pass Off the trailer tonight #2699391
09/20/19 10:16 PM
09/20/19 10:16 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
Seems light on the top end,,,gonna jet up some more .....So the Hemi runs....just not where I want it to yet....Still a 9second street car. Should be a 9.60 street car,,,,,
Re: Hemi Cuda.....1st Pass Off the trailer tonight [Re: Dragula] #2699438
09/21/19 08:25 AM
09/21/19 08:25 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
NICE!!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Hemi Cuda.....1st Pass Off the trailer tonight [Re: hemi-itis] #2699450
09/21/19 09:20 AM
09/21/19 09:20 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Nice light, and 60'. With the 1/8th mile E/T, it should have a low 9.80 in it, but mph doesn't show it. This is the 605 HEMI correct?
69 GTX 68 Road Runner
Re: Hemi Cuda.....1st Pass Off the trailer tonight [Re: JERICOGTX] #2699454
09/21/19 09:33 AM
09/21/19 09:33 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Nice light
The 1/8 mph is soft
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Hemi Cuda.....1st Pass Off the trailer tonight [Re: B3422W5] #2699570
09/21/19 05:54 PM
09/21/19 05:54 PM
Dragula Offline OP
Dragula  Offline OP
Had a blast this weekend....And this was the best pass on the car to date.....
Re: Hemi Cuda.....1st Pass Off the trailer tonight [Re: Dragula] #2699577
09/21/19 06:16 PM
09/21/19 06:16 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Nice. Your vert flashes about the same as mine, 5000, 5100. I would be very happy with a pass like that.
Re: Hemi Cuda.....1st Pass Off the trailer tonight [Re: mopar dave] #2699589
09/21/19 06:48 PM
09/21/19 06:48 PM
Dragula Offline OP
Dragula  Offline OP
It's not supposed to flash that high with this engine......it's a blown alky convertor from ATI.... supposed to be 3600, but I am pretty happy with it. I will have to get stiffer side wall slicks for next year. It's crushing my current tires.
Re: Hemi Cuda.....1st Pass Off the trailer tonight [Re: Dragula] #2699603
09/21/19 07:11 PM
09/21/19 07:11 PM
Penna
70satelliteguy Offline
Penna
One of the best in car videos I have seen!! Your reaction times are unreal.
Now you have to put a cage in it before you get booted!! LOL
Mike
Re: Hemi Cuda.....1st Pass Off the trailer tonight [Re: 70satelliteguy] #2699666
09/21/19 10:33 PM
09/21/19 10:33 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Nice!
I was wondering where the roll cage was, too.
Re: Hemi Cuda.....1st Pass Off the trailer tonight [Re: 70satelliteguy] #2699670
09/21/19 10:42 PM
09/21/19 10:42 PM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
Very nice! Are you going to stick with the hemi a while longer?
Re: Hemi Cuda.....1st Pass Off the trailer tonight [Re: gsmopar] #2699728
09/22/19 08:09 AM
09/22/19 08:09 AM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
72 Plymouth Roadrunner 11.08@123.25
Re: Hemi Cuda.....1st Pass Off the trailer tonight [Re: Roughbird72] #2699775
09/22/19 10:37 AM
09/22/19 10:37 AM
Dragula Offline OP
Dragula  Offline OP
Agreed, we are a little light on the cage. I only have a roll bar in it and never really wanted to cut the car up more, but I like running 9's with it so it is time to step it up with a full cage and window net.
I was hoping the car would have run closer to its potential, but I ran out of bigger jets at #106 in all four corners and 6.20's made me happy for now. The timing I set by ear, and I will have to see where it ended up. I am hoping there is more potential left in this combo than just 9.90. I feel this combo should run 9.60 for a 605...unless the weight of my car is that far off. Haven't weighted it in years and this block is heavy.
I am curious though, is anyone running the Barton rockers? Would those be worth the $ and did they free up any HP?
The other issue seems the lack of traction. The car made more hp, but ever run I had a worse 60ft. Its crushing the rear tires even at 14psi,so it looks like I need to find a better solution there. I am not sure I can do anything else with the suspension....
Re: Hemi Cuda.....1st Pass Off the trailer tonight [Re: Dragula] #2699797
09/22/19 11:23 AM
09/22/19 11:23 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Nice smooth trip
Down the track. Great video.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Hemi Cuda.....1st Pass Off the trailer tonight [Re: pittsburghracer] #2699928
09/22/19 07:17 PM
09/22/19 07:17 PM
Dragula Offline OP
Dragula  Offline OP
My 6.25 pass.....
Re: Hemi Cuda.....1st Pass Off the trailer tonight [Re: Dragula] #2700002
09/22/19 11:22 PM
09/22/19 11:22 PM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
I have the Barton rockers. Similar build with less cylinder head. I'm real close to getting mine back on the road/track.
Re: Hemi Cuda.....1st Pass Off the trailer tonight [Re: gsmopar] #2700021
09/23/19 04:29 AM
09/23/19 04:29 AM
Germany
stickman60 Offline
stickman60  Offline
Germany
Gorgeous how the Hemi is singing!!
Re: Hemi Cuda.....1st Pass Off the trailer tonight [Re: stickman60] #2700023
09/23/19 05:48 AM
09/23/19 05:48 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
At what rpm are you shifting? Didn't look like it was going much past 6000.
Re: Hemi Cuda.....1st Pass Off the trailer tonight [Re: quickd100] #2700052
09/23/19 09:06 AM
09/23/19 09:06 AM
an8sec70cuda Offline
What was the DA?
Like quickd100 said, it doesn't sound like you're spinning it real hard, but the video may be deceiving.
Have you tried leaving off a fast idle? You are footbraking right?
Just looked through my logbooks, and my closest comparable timeslip running mid 6.20s are all at 109-110+ mph.
You're still on a big bias ply tire though right? That might be why.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Hemi Cuda.....1st Pass Off the trailer tonight [Re: an8sec70cuda] #2700075
09/23/19 10:37 AM
09/23/19 10:37 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Mine goes 111mph at 6.20's, but only have gone 1.37 60'.
Re: Hemi Cuda.....1st Pass Off the trailer tonight [Re: BradH] #2700082
09/23/19 10:44 AM
09/23/19 10:44 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Originally Posted by BradH
Nice!
Since he is running IHRA, he doesn't need a cage until 9.00 or faster. Does need a IHRA license though to go under 6.40, or 10.00.
Page 1 of 3 1 2 3
