Page 1 of 3 1 2 3
Hemi Cuda.....1st Pass Off the trailer tonight #2699391
09/20/19 10:16 PM
09/20/19 10:16 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
Seems light on the top end,,,gonna jet up some more .....So the Hemi runs....just not where I want it to yet....Still a 9second street car. Should be a 9.60 street car,,,,,
Re: Hemi Cuda.....1st Pass Off the trailer tonight [Re: Dragula] #2699438
09/21/19 08:25 AM
09/21/19 08:25 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
NICE!!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Hemi Cuda.....1st Pass Off the trailer tonight [Re: hemi-itis] #2699450
09/21/19 09:20 AM
09/21/19 09:20 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Nice light, and 60'. With the 1/8th mile E/T, it should have a low 9.80 in it, but mph doesn't show it. This is the 605 HEMI correct?
69 GTX 68 Road Runner
Re: Hemi Cuda.....1st Pass Off the trailer tonight [Re: JERICOGTX] #2699454
09/21/19 09:33 AM
09/21/19 09:33 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Nice light
The 1/8 mph is soft
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Hemi Cuda.....1st Pass Off the trailer tonight [Re: B3422W5] #2699570
09/21/19 05:54 PM
09/21/19 05:54 PM
Dragula Offline OP
Dragula  Offline OP
Had a blast this weekend....And this was the best pass on the car to date.....
Re: Hemi Cuda.....1st Pass Off the trailer tonight [Re: Dragula] #2699577
09/21/19 06:16 PM
09/21/19 06:16 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Nice. Your vert flashes about the same as mine, 5000, 5100. I would be very happy with a pass like that.
Re: Hemi Cuda.....1st Pass Off the trailer tonight [Re: mopar dave] #2699589
09/21/19 06:48 PM
09/21/19 06:48 PM
Dragula Offline OP
Dragula  Offline OP
It's not supposed to flash that high with this engine......it's a blown alky convertor from ATI.... supposed to be 3600, but I am pretty happy with it. I will have to get stiffer side wall slicks for next year. It's crushing my current tires.
Re: Hemi Cuda.....1st Pass Off the trailer tonight [Re: Dragula] #2699603
09/21/19 07:11 PM
09/21/19 07:11 PM
Penna
70satelliteguy Offline
Penna
One of the best in car videos I have seen!! Your reaction times are unreal.
Now you have to put a cage in it before you get booted!! LOL
Mike
Re: Hemi Cuda.....1st Pass Off the trailer tonight [Re: 70satelliteguy] #2699666
09/21/19 10:33 PM
09/21/19 10:33 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Nice!
I was wondering where the roll cage was, too.
Re: Hemi Cuda.....1st Pass Off the trailer tonight [Re: 70satelliteguy] #2699670
09/21/19 10:42 PM
09/21/19 10:42 PM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
Very nice! Are you going to stick with the hemi a while longer?
Re: Hemi Cuda.....1st Pass Off the trailer tonight [Re: gsmopar] #2699728
09/22/19 08:09 AM
09/22/19 08:09 AM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
72 Plymouth Roadrunner 11.08@123.25
Re: Hemi Cuda.....1st Pass Off the trailer tonight [Re: Roughbird72] #2699775
09/22/19 10:37 AM
09/22/19 10:37 AM
Dragula Offline OP
Dragula  Offline OP
Agreed, we are a little light on the cage. I only have a roll bar in it and never really wanted to cut the car up more, but I like running 9's with it so it is time to step it up with a full cage and window net.
I was hoping the car would have run closer to its potential, but I ran out of bigger jets at #106 in all four corners and 6.20's made me happy for now. The timing I set by ear, and I will have to see where it ended up. I am hoping there is more potential left in this combo than just 9.90. I feel this combo should run 9.60 for a 605...unless the weight of my car is that far off. Haven't weighted it in years and this block is heavy.
I am curious though, is anyone running the Barton rockers? Would those be worth the $ and did they free up any HP?
The other issue seems the lack of traction. The car made more hp, but ever run I had a worse 60ft. Its crushing the rear tires even at 14psi,so it looks like I need to find a better solution there. I am not sure I can do anything else with the suspension....
Re: Hemi Cuda.....1st Pass Off the trailer tonight [Re: Dragula] #2699797
09/22/19 11:23 AM
09/22/19 11:23 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Nice smooth trip
Down the track. Great video.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Hemi Cuda.....1st Pass Off the trailer tonight [Re: pittsburghracer] #2699928
09/22/19 07:17 PM
09/22/19 07:17 PM
Dragula Offline OP
Dragula  Offline OP
My 6.25 pass.....
Re: Hemi Cuda.....1st Pass Off the trailer tonight [Re: Dragula] #2700002
09/22/19 11:22 PM
09/22/19 11:22 PM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
I have the Barton rockers. Similar build with less cylinder head. I'm real close to getting mine back on the road/track.
Re: Hemi Cuda.....1st Pass Off the trailer tonight [Re: gsmopar] #2700021
09/23/19 04:29 AM
09/23/19 04:29 AM
Germany
stickman60 Offline
stickman60  Offline
Germany
Gorgeous how the Hemi is singing!!
Re: Hemi Cuda.....1st Pass Off the trailer tonight [Re: stickman60] #2700023
09/23/19 05:48 AM
09/23/19 05:48 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
At what rpm are you shifting? Didn't look like it was going much past 6000.
Re: Hemi Cuda.....1st Pass Off the trailer tonight [Re: quickd100] #2700052
09/23/19 09:06 AM
09/23/19 09:06 AM
an8sec70cuda Online content
an8sec70cuda  Online Content
What was the DA?
Like quickd100 said, it doesn't sound like you're spinning it real hard, but the video may be deceiving.
Have you tried leaving off a fast idle? You are footbraking right?
Just looked through my logbooks, and my closest comparable timeslip running mid 6.20s are all at 109-110+ mph.
You're still on a big bias ply tire though right? That might be why.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Hemi Cuda.....1st Pass Off the trailer tonight [Re: an8sec70cuda] #2700075
09/23/19 10:37 AM
09/23/19 10:37 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Mine goes 111mph at 6.20's, but only have gone 1.37 60'.
Re: Hemi Cuda.....1st Pass Off the trailer tonight [Re: BradH] #2700082
09/23/19 10:44 AM
09/23/19 10:44 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Originally Posted by BradH
Nice!
Since he is running IHRA, he doesn't need a cage until 9.00 or faster. Does need a IHRA license though to go under 6.40, or 10.00.
Page 1 of 3 1 2 3
