Re: Holley 770 Super Stock Carb problem
[Re: fbs63]
#2699092
09/19/19 08:46 PM
09/19/19 08:46 PM
fast68plymouth
So. Burlington, Vt.
I’m going with........ the check needles(under the squirters) are either stuck or missing.
[Re: fast68plymouth]
#2699110
09/19/19 10:22 PM
09/19/19 10:22 PM
Posts: 1,824 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
I’m going with........ the check needles(under the squirters) are either stuck or missing. How do I get to them? Not familiar with these carbs.
[Re: krautrock]
#2700143
09/23/19 01:37 PM
09/23/19 01:37 PM
Posts: 4,760 Moved to N.E. Tennessee
GomangoCuda
All good info above but there is another possibility. A long time ago Someone asked me to look at a Holley that they rebuilt and had problem with the accelerator pump. Turned out the bowl gasket only had one hole for the accelerator pump passage and yes of coarse the gasket was backwards, perfectly blocking the passage.
Just remembered a brand new carb with a doa accelerator pump. The nozzle screw was pushing the check valve into it's seat. Screw was defective. Simple fix.
