Holley 770 Super Stock Carb problem #2699063
09/19/19 07:04 PM
09/19/19 07:04 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Cant get the squirters to work on a OE magnesium crossram on my Hemi Dart.
I changed the accelerator pumps on both carbs.
Poured a little fuel into carbs and car starts right up.
Runs fine but the accelerator pumps dont work.
I put in OE Holley accelerator pumps too.
What am I doing wrong?
They worked initially the 1st day I put them in but 5 days later they dont work.
Re: Holley 770 Super Stock Carb problem [Re: Sammy] #2699065
09/19/19 07:11 PM
09/19/19 07:11 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Did the bowls have check balls or the rubber check flap in them?
Re: Holley 770 Super Stock Carb problem [Re: fbs63] #2699092
09/19/19 08:46 PM
09/19/19 08:46 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I’m going with........ the check needles(under the squirters) are either stuck or missing.
Re: Holley 770 Super Stock Carb problem [Re: fast68plymouth] #2699110
09/19/19 10:22 PM
09/19/19 10:22 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
How do I get to them?
Not familiar with these carbs.
Re: Holley 770 Super Stock Carb problem [Re: Sammy] #2699137
09/20/19 01:47 AM
09/20/19 01:47 AM
The accelerator pump squirter is mounted between the front two barrels inside the front half of the carb, it is held in with a large Phillips head screw that is hollow to allow fuel to squirt up through it into the carb. The check valve is under the squirter. Remove the screw and squrtier without loosing either gasket and then roll the carb over a clean flat surface to see if the check valve or check ball will drop out scope Most Holley carbs have a square brass check valve that has a tapered point on it that sits on a machine seat in the carb body to stop the gas flow from siphoning after the accelerator pump is done squirting fuel into the carb. scope If it won't drop out hold the arb upside down and tap on the bottom of it gently several times to see if it will jar loose and drop out luck wrench
Re: Holley 770 Super Stock Carb problem [Re: Cab_Burge] #2699164
09/20/19 09:29 AM
09/20/19 09:29 AM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
Re: Holley 770 Super Stock Carb problem [Re: krautrock] #2700143
09/23/19 01:37 PM
09/23/19 01:37 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
All good info above but there is another possibility. A long time ago Someone asked me to look at a Holley that they rebuilt and had problem with the accelerator pump. Turned out the bowl gasket only had one hole for the accelerator pump passage and yes of coarse the gasket was backwards, perfectly blocking the passage.
Just remembered a brand new carb with a doa accelerator pump. The nozzle screw was pushing the check valve into it's seat. Screw was defective. Simple fix.
