Marker light sockets, where to get? #269828
03/28/09 07:41 PM
03/28/09 07:41 PM
Virginia, US
RTDaddy Offline OP
super street
RTDaddy  Offline OP
super street
Virginia, US
OK, I know I can't be the first one to hit thie. Where can you get replacement sockets to pop in the marker light housings like on 70 Chargers and Challengers? The rear harnesses that Evans makes has the pop in type of socket, where can you get those to do that to the front? I know I will have to run a ground lead to the housings. Any/all help appreciated.
"IF YOU'RE UNDER CONTROL, YOU AIN'T GOING FAST ENOOUGH."
Re: Marker light sockets, where to get? [Re: RTDaddy] #269829
03/28/09 07:57 PM
03/28/09 07:57 PM
wilmington,ohio
O
ohiodemon Offline
ohiodemon  Offline
O
wilmington,ohio
have you tried NAPA ?
Re: Marker light sockets, where to get? [Re: ohiodemon] #269830
03/28/09 09:15 PM
03/28/09 09:15 PM
Virginia, US
RTDaddy Offline OP
super street
RTDaddy  Offline OP
super street
Virginia, US
Yup,
They have those that fit the taillights, (1157 bulbs), and a hole about the size of a quarter. I need one to fit the 1895 bulbs, goes in hole about the size of a nickel.
"IF YOU'RE UNDER CONTROL, YOU AIN'T GOING FAST ENOUGH."
Re: Marker light sockets, where to get? [Re: RTDaddy] #269831
03/29/09 08:57 PM
03/29/09 08:57 PM
Virginia, US
RTDaddy Offline OP
super street
RTDaddy  Offline OP
super street
Virginia, US
anyone else?
Re: Marker light sockets, where to get? [Re: RTDaddy] #269832
03/29/09 11:10 PM
03/29/09 11:10 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
What do they look like? Have a pic you could post?
Re: Marker light sockets, where to get? [Re: In_The_Pink] #269833
03/30/09 09:09 AM
03/30/09 09:09 AM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
got a couple for my truck from Car Quest; made in Taiwan and crap! The b/u light one works but the tail light one would NOT unless I held pressure against the bulb to help it make contact!
Re: Marker light sockets, where to get? [Re: volaredon] #269834
03/30/09 01:26 PM
03/30/09 01:26 PM
PA
70Duster Offline
70Duster  Offline
PA
He's asking where to get the SIDE MARKER light sockets. Not tail light, brake light or back-up light sockets. I'd be interested in this source as well.
Re: Marker light sockets, where to get? [Re: volaredon] #269835
03/30/09 01:37 PM
03/30/09 01:37 PM
United States
STLDuster Offline
STLDuster  Offline
United States
I just got some from Oreilys autoparts. I am going to work on installing them this weekend.
May be the same parts as Napa?
"No great genius has ever existed without some touch of madness." - Aristotle
Re: Marker light sockets, where to get? [Re: STLDuster] #269836
03/30/09 02:28 PM
03/30/09 02:28 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Is this the same style socket E-body SMLs use? If so, I should have some ends I can cut and send you off some partial wiring harnesses.
Re: Marker light sockets, where to get? [Re: In_The_Pink] #269837
03/30/09 04:37 PM
03/30/09 04:37 PM
Virginia, US
RTDaddy Offline OP
super street
RTDaddy  Offline OP
super street
Virginia, US
Exactly, E-body side marker lights. The rears are one wire and "snap" into the housings. This is what I'm looking for. I appreciate your willing to cut some off, but there has to be a source out there, as the new wiring harnesses which are sold have these on them. Anyone have a source?
Re: Marker light sockets, where to get? [Re: RTDaddy] #269838
03/30/09 10:34 PM
03/30/09 10:34 PM
Rochester HIlls, MI
Blue66Charger Offline
Rochester HIlls, MI
Pico light bulb sockets. Summit carries them I think. A little surfing and you might be golden.
