Diagnose Latest Build 440 6Pack ?!?!? #2696068
09/10/19 10:21 AM
09/10/19 10:21 AM
Cent, OH
Mopar.70 Offline OP
Mopar.70  Offline OP
Cent, OH
Moparts World. I've wrapped up my latest resto on my 71 Challenger 440 6 pack. Car was stripped down to a bare shell and a basketcase project. So I feel great I saved it from the grave and it's a great feeling to drive this thing down the road! But I don't quite feel it's preforming like I planned for it. It's not a numbers car, although my goal was as stock appearing as possible it does have headers and 4 core alum. radiator. I'll give the spec's on it below and history below and if you would help me trouble shoot this build and see if anything glaring pops out at you.
Tanny woes: The first drive in this thing yielded some transmission issues. It wouldn't shift out of 1st gear, pulling the trans and going thru it we found a port was plugged preventing pressure to allow the 1st to 2nd shift. One thing I recall during the first run, car felt like I thought it would in 1st, didn't take much to spin the tires, just a tap of the pedal. So even though everything was rebuilt and new in the tranny, I had bought a full kit for it and put it all in new and upgrade low/reverse band and kickdown lever to 5.0 ratio. Car now shifts into all gears, and drives fine. It will do a burnout, but it's not as scary as I figured it would be with 440 six pack. Car seems "labored" or sluggish". Seems something is robbing it of power. Not alot of low end power, but if you stomp on it while in 3rd gear it pulls hard on the top end. I planned for more torque and low end power than top end power? He's what's in it that I can think of off the top of my head. I'm not sure if it's converter, gear, bad tranny build, bad valve body, timming etc. . .
- 440 .040 over with KB pistons, 915 closed chamber heads that have been milled a tad and slight port/bowl work. 2.14/1.84 valves I believe. Lunati voodoo hydraulic .534/.513 cam (builder said would give 10.1 comp with piston/head combo)
- 6 pack is the direction connection aftermarket mech set
- 3,000 stall converter (Hughes, new)
- 3:55 gear
- 275/60 R 15 tires
-727 has factory valve body, it's a 64 model, but was an old race tranny. Had HD drum and other items to "beef" it up. I'm not a tranny wiz, but have been told by multiple people it has the right stuff in it. But recently had to tighten low/reverse band. Drove around a summer with it to loose.
Re: Diagnose Latest Build 440 6Pack ?!?!? [Re: Mopar.70] #2696088
09/10/19 11:02 AM
09/10/19 11:02 AM
moparx Offline
moparx  Offline
are you sure your transmission has a 64 valvebody ? those were cable operated and had a different case and tailshaft casting.[among other drastic differences.]
perhaps you meant a 74 valvebody ?
beer
Re: Diagnose Latest Build 440 6Pack ?!?!? [Re: moparx] #2696095
09/10/19 11:16 AM
09/10/19 11:16 AM
Missouri
randavis Offline
randavis  Offline
Missouri
I had a 64 Polara 500 2dr hardtop with a floor shifted 727. That tranny was not cable shifted. He could have one of those.
Just sayin'
74 Challenger, bought it new. In 1978 I replaced the original 318 with a 446 and 727. Mild cam, Jardine headers, and Holley Sniper EFI.
New engine! 511" RB, Edelbrock Performer RPM heads, Eagle rotating assy, Comp hyd roller cam, Doug's 2" headers.
Re: Diagnose Latest Build 440 6Pack ?!?!? [Re: randavis] #2696096
09/10/19 11:20 AM
09/10/19 11:20 AM
Cent, OH
Mopar.70 Offline OP
Mopar.70  Offline OP
Cent, OH
I know the body of the trans is a 64. I believe at the time when we looked at the valve body the date code on it matched up, but I can't recall now. The trans has been modified plenty, it's not a stock trans that has just been rebuilt. I bought it already rebuilt from someone here on Moparts years ago. But pretty sure it had a manual valve body in it with that port being plugged.
Re: Diagnose Latest Build 440 6Pack ?!?!? [Re: randavis] #2696114
09/10/19 12:05 PM
09/10/19 12:05 PM
SW CO
HemiSportFury Offline
SW CO
Just sayin'
The 64 council shifted 727s were still cable shift. Just from the shifter instead of the pushbuttons.
'64 Sport Fury, 528 Hemi, FiTech EFI, 4-speed, 4.10 Dana 60
'57 Belvedere 2dr sedan, current project in process
'19 Cherokee Trail Hawk Elite
'03 Ram 2500 CTD HO, 6-speed 214,000 miles and still going strong
Re: Diagnose Latest Build 440 6Pack ?!?!? [Re: Mopar.70] #2696125
09/10/19 12:20 PM
09/10/19 12:20 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
- 3:55 gear
- 275/60 R 15 tires
You want some low end grunt/balls from that combo, dump that pig of a converter, get yourself into the 1800-2000 RPM stall range before even dialing in the carbs/timing IMHO
Mike
Re: Diagnose Latest Build 440 6Pack ?!?!? [Re: DAYCLONA] #2696290
09/10/19 07:23 PM
09/10/19 07:23 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
So you are suggesting he put a stock converter in his car? I completely disagree. 3000 stall sounds about right to me. I can't vouch for the quality of Hughes products though. I'm assuming the OP has the this cam: https://www.summitracing.com/parts/lun-10230704/overview/make/plymouth Combo ought to be good for 12s with traction.
Re: Diagnose Latest Build 440 6Pack ?!?!? [Re: forphorty] #2696292
09/10/19 07:51 PM
09/10/19 07:51 PM
Cent, OH
Mopar.70 Offline OP
Mopar.70  Offline OP
Cent, OH
That's the can I'm running. Traction is no problem. It won't really spin em. If you power brake, it'll do a burnout. But nothing glamorous
Re: Diagnose Latest Build 440 6Pack ?!?!? [Re: Mopar.70] #2696295
09/10/19 08:13 PM
09/10/19 08:13 PM
A727Tflite Online content
A727Tflite  Online Content
You don’t mention who built the engine.
Regardless if these parts play together nicely or not:
Was cam degreed in? If so, what is it set at?
Was TDC checked against the damper on the engine?
What is the total timing set at, and when does it come in? What is your total timing?
Did you check for wide open throttle. Not only the center carb but the front and rear?
Did you check compression - if so what Is it?
Re: Diagnose Latest Build 440 6Pack ?!?!? [Re: A727Tflite] #2696302
09/10/19 08:50 PM
09/10/19 08:50 PM
Cent, OH
Mopar.70 Offline OP
Mopar.70  Offline OP
Cent, OH
I built the engine (not my first engine build), but had a fellow member here/drag racer dial in the cam. He checked TDC, set the cam per the card and no offset in degrees. Verified what he did to with degree wheel etc.
TDC checked with damper and piston travel
Timing is one thing I changed, when we set it, we set it at 36 at 2,000 rpm, that was without vacuum advance set up. Plugged in the vac. ad. and ran it for awhile. Check it with vac. ad. hooked up and once you leave idle it would just go into outter space off the damper with increase of RPM. So plugged vacuum advance and it holds 36 all the way up to 3,000 ish when we checked it. I did put the light weight springs in the distributor.
WOT seems right on, pedal does give you WOT. I could adjust when outboards come in since they are mech on progressive linkage but I haven't.
Did not verify compression
The motor runs fine, idles well, great throttle response, seems normal and uncapped it's LOUD, like my small block drag car was. The one and only thing I felt uneasy about with the engine was I bought pushrods from 440 source that are for hydraulic cam, and mech rockers. I don't have factory hyd rockers. They are isky iron rockers. I didn't do a custom push rod length check. But the length of adjuster screw out of the rocker was good.
Could add I have magnaflow 2-1/2 exhaust with x pipe.
Re: Diagnose Latest Build 440 6Pack ?!?!? [Re: Mopar.70] #2696312
09/10/19 09:15 PM
09/10/19 09:15 PM
NC, USA
davenc Offline
davenc  Offline
NC, USA
With vacuum advance unplugged from distributor (and the line plugged) what is the initial advance?
Re: Diagnose Latest Build 440 6Pack ?!?!? [Re: davenc] #2696313
09/10/19 09:20 PM
09/10/19 09:20 PM
Cent, OH
Mopar.70 Offline OP
Mopar.70  Offline OP
Cent, OH
It will read 36-37 degrees no matter if your at idle or come up in RPM. I think because the light weight springs
Re: Diagnose Latest Build 440 6Pack ?!?!? [Re: Mopar.70] #2696316
09/10/19 09:34 PM
09/10/19 09:34 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I would try setting the timing at 18* at idle with the vacuum advance disconnected and the vacuum line plugged.
Re: Diagnose Latest Build 440 6Pack ?!?!? [Re: Mopar.70] #2696341
09/10/19 10:21 PM
09/10/19 10:21 PM
NC, USA
davenc Offline
davenc  Offline
NC, USA
With 10:1 and iron heads, I would expect the motor to ping badly with that much initial. Sometimes way over advanced can kill power. This is definitely an area to improve in your combo (hot street engine). As stated 18-22 initial with the remainder in by 2500 or so. Timing curve can make a big difference in the power characteristics.
Re: Diagnose Latest Build 440 6Pack ?!?!? [Re: Mopar.70] #2696374
09/11/19 12:51 AM
09/11/19 12:51 AM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
I had a set of Mr Gasket springs in a single point dist back in the 80s that reached full advance at 1100 or thereabouts.
Re: Diagnose Latest Build 440 6Pack ?!?!? [Re: forphorty] #2696393
09/11/19 06:21 AM
09/11/19 06:21 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
My bet it's a combination of items. As a test disconnect the linkage from the outer carbs. Run just on the center carb. My bet is it'll wake up the bottom big time. The solid carb linkage is not the ticket for low end street use If this does indead fix it, consider going back to the factory vacuum secondary linkage. Even the factory stuff can be adjusted to open to quick if you run the lightest springs in the vacuum pods.
Doug
Re: Diagnose Latest Build 440 6Pack ?!?!? [Re: dvw] #2696573
09/11/19 02:34 PM
09/11/19 02:34 PM
Cent, OH
Mopar.70 Offline OP
Mopar.70  Offline OP
Cent, OH
I'll try the timing and carb adjustments listed. Thanks guys!
Re: Diagnose Latest Build 440 6Pack ?!?!? [Re: Mopar.70] #2749342
03/05/20 05:50 PM
03/05/20 05:50 PM
Rome, GA
GTXX Offline
GTXX  Offline
Rome, GA
If you're still having problems with this, use the lightest of the stock springs and only one of the lightweight springs and leave the vacuum advance capped off, this should solve the problem of it going to full advance at idle. Set your total at 36-38.
'71 GTX w/Air Grabber, Super Trak Pak, Spoiler Pkg. been apart for 22 years, thinking it's time to do something about that....
Re: Diagnose Latest Build 440 6Pack ?!?!? [Re: stumpy] #2749350
03/05/20 06:26 PM
03/05/20 06:26 PM
God's Country Maryland
GODSCOUNTRY340 Offline
Stumpy is right on, that cam needs to be advanced at idle. If it then has too much total advance you'll need to restrict that with the slots in the distributor (usually by shortening them by welding and filing until you get the desired total advance)
Re: Diagnose Latest Build 440 6Pack ?!?!? [Re: GODSCOUNTRY340] #2749396
03/05/20 08:13 PM
03/05/20 08:13 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Originally Posted by GODSCOUNTRY340
.......that cam needs to be advanced at idle.......
Is that what you meant to say? If so, you might want to add some clarification for the OP.
