Pilot bearing on input shaft
#2695918
09/09/19 08:02 PM
09/09/19 08:02 PM
Posts: 1,487 STL
cdstl
STL
I’ve pieced together a 4 speed for my 72 Cuda. It’s all together and moving under it’s own power.
The trans is from a 70 B body with the dual shifter locations.
The reason for the post is this. You could see where the pilot bushing had worn a spot on the input shaft. A in my picture. When I installed my trans checked the depth of the input shaft to make sure that I wouldn’t hit the crank. I didn’t but the pilot bushing is right up next to the splines on the input shaft like they are in the B in my picture.
Do you guys think that I’ll have a problem? I called Brewer’s and he thought that I’d be ok.
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Pilot bearing on input shaft
[Re: cdstl]
#2695919
09/09/19 08:07 PM
09/09/19 08:07 PM
Posts: 6,258 nowhere
Sniper
nowhere
Which pilot bushing are you using? the thin tube type that goes inside the drilled hole in the crank or the type that uses the centering ring? IOW this or this ?
[Re: cdstl]
#2695937
09/09/19 08:42 PM
09/09/19 08:42 PM
Posts: 1,487 STL
cdstl
STL
It's a bearing and it's in my crankshaft.
The question that I have is whether or not the input shaft will "flop around" since the bearing is so far aft of where the pilot BUSHING had been on the previous car.
Dan, that's a hell of a graphic. I wish I had seen it before.
Does it matter where the the bushing or bearing falls along the length of the input shaft?
[Re: cdstl]
#2695952
09/09/19 09:33 PM
09/09/19 09:33 PM
Posts: 766 Ohio
Dan Brewer
Ohio
Thanks Like mentioned above, as long as there is a bushing or bearing in place you are good to go.
[Re: moparpoolman]
#2696020
09/10/19 06:04 AM
09/10/19 06:04 AM
Posts: 1,487 STL
cdstl
STL
"Do you guys think that I’ll have a problem? I called Brewer’s and he thought that I’d be ok."
You already got your answer from the best person you could possibly get an answer from, why ask again?... Agreed. Thanks for the extra input.
