New PB and a wheelstand Vid #2695839
09/09/19 04:10 PM
09/09/19 04:10 PM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
Hi All.
We ran a PB over the last weekend keeping up the New PB every meeting this year. It's ran a 9.51 which is a PB for the 572 motor mph is the same so its all down to the chassis.
Here's the Vid https://www.youtube.com/watch?v=D4B_QewPIhc
Re: New PB and a wheelstand Vid [Re: Tig] #2695840
09/09/19 04:17 PM
09/09/19 04:17 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Very impressive. I love it!
Re: New PB and a wheelstand Vid [Re: Tig] #2695855
09/09/19 04:56 PM
09/09/19 04:56 PM
Cab_Burge Online work
Cab_Burge  Online Work
I would try lowering the wheelie bars so it doesn't spend so much time going up instead of forward as fast as it can the first 100 Ft. work scope twocents
Re: New PB and a wheelstand Vid [Re: Cab_Burge] #2695863
09/09/19 05:06 PM
09/09/19 05:06 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
nice
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: New PB and a wheelstand Vid [Re: Cab_Burge] #2695870
09/09/19 05:12 PM
09/09/19 05:12 PM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
We've found lowering the wheelie bar unloads the tyre when the bars stop, It's uses a radial tyre. It's a fine line between wheelstanding and spinning,you can just see it unloading around 40 seconds in. We would be better off with the Caltrac mono bar than the axle mount wheelie bars fitted now but have the tank in the stock position.
thanks Bigdad for putting up the link
Re: New PB and a wheelstand Vid [Re: Tig] #2696042
09/10/19 08:11 AM
09/10/19 08:11 AM
an8sec70cuda Offline
Looking good Tig!! I was gonna say that I bet lowering the bars will unload it. Looks like the radials are working for you!
Tighten up those front shocks to keep the front down.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: New PB and a wheelstand Vid [Re: an8sec70cuda] #2696149
09/10/19 01:39 PM
09/10/19 01:39 PM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
Thanks Chip. We turned another flat for tighter extension after that one, we were into a headwind the next day. Less height but then span on the last two passes.
Re: New PB and a wheelstand Vid [Re: Tig] #2696156
09/10/19 02:02 PM
09/10/19 02:02 PM
tboomer Online work
tboomer  Online Work
Great video! Congrats Tig! wave
