Upper ball joint sleeve from smaller joint to larger #269561
03/28/09 01:44 PM
03/28/09 01:44 PM
Anonymous OP
Anonymous OP
I am converting over to disc brakes and need to know where I can get sleeve for smaller joint to a larger spindle? Does anyone know where I can purchase the sleeve to convert it over? Its on a 71 Duster and took the brakes off 77 Lebaron. Thank you
Re: Upper ball joint sleeve from smaller joint to larger #269562
03/28/09 03:11 PM
03/28/09 03:11 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
sorry,,, but you are looking for something that doesnt exhist.... you need the 73 and newer A body upper control arms
I am truckless..
Re: Upper ball joint sleeve from smaller joint to larger [Re: 340SHORTY] #269563
03/29/09 09:01 AM
03/29/09 09:01 AM
moparx Online content
moparx  Online Content
the sleeve you need is from speedway motors.
part # : 910-34812 fits moog k772 upper joint.
price : $7.99 ea.
these sleeves are 1" thick, so you need to machine them to the thickness of the sleeve in the upper control arm so you can use the o.e. dust cover. hope this helps.
Re: Upper ball joint sleeve from smaller joint to larger [Re: moparx] #269564
03/29/09 10:54 AM
03/29/09 10:54 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I think he is looking for a tapered sleeve to connect a small ball joint to a large knuckle.
Re: Upper ball joint sleeve from smaller joint to larger [Re: DoctorDiff] #269565
03/30/09 09:23 PM
03/30/09 09:23 PM
i remember seeing something along this line someplace, but i couldn't tell for sure if the tapers were what was needed for this application. i should have noted where this came from, as my mind draws a blank now
Re: Upper ball joint sleeve from smaller joint to larger [Re: moparx] #269566
03/30/09 11:27 PM
03/30/09 11:27 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I found a pair of tapered (tie rod end) adapters when I installed F-150 disc brakes on a '76 and older Bronco front end a few years ago.
I don't know if they would work on A-body UCA ball joints, however.
Re: Upper ball joint sleeve from smaller joint to larger #269567
03/31/09 04:24 PM
03/31/09 04:24 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The e-bay link below shows a Ford tapered sleeve, they might be the same taper as Mopar. I would ask the vendor.
http://cgi.ebay.com/ebaymotors/Mustang-F...emZ110297387673
Re: Upper ball joint sleeve from smaller joint to larger [Re: John_Kunkel] #269568
03/31/09 09:12 PM
03/31/09 09:12 PM
i would think the tierod would have a smaller taper than the balljoint. however, in my moog master catalog, there is a section that lists the specs of tierod tapers. i'll have to take the time to check this. in the mean time, i found a balljoint taper adapter in my afco catalog. it doesn't really say much as to what it fits. the part # is : 200388. i tryed to look it up on line, but it wasn't listed.
