Upper ball joint sleeve from smaller joint to larger
#269561
03/28/09 01:44 PM
03/28/09 01:44 PM
I am converting over to disc brakes and need to know where I can get sleeve for smaller joint to a larger spindle? Does anyone know where I can purchase the sleeve to convert it over? Its on a 71 Duster and took the brakes off 77 Lebaron. Thank you
Re: Upper ball joint sleeve from smaller joint to larger
#269562
03/28/09 03:11 PM
03/28/09 03:11 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
sorry,,, but you are looking for something that doesnt exhist.... you need the 73 and newer A body upper control arms
I am truckless..
[Re: 340SHORTY]
#269563
03/29/09 09:01 AM
03/29/09 09:01 AM
Posts: 19,456 north of coder
moparx
the sleeve you need is from speedway motors. part # : 910-34812 fits moog k772 upper joint. price : $7.99 ea. these sleeves are 1" thick, so you need to machine them to the thickness of the sleeve in the upper control arm so you can use the o.e. dust cover. hope this helps.
[Re: DoctorDiff]
#269565
03/30/09 09:23 PM
03/30/09 09:23 PM
moparx
I think he is looking for a tapered sleeve to connect a small ball joint to a large knuckle.
i remember seeing something along this line someplace, but i couldn't tell for sure if the tapers were what was needed for this application. i should have noted where this came from, as my mind draws a blank now
