Re: B1 question
[Re: e85mope]
#2695762
09/09/19 12:14 PM
09/09/19 12:14 PM
Posts: 19,384 Las Vegas
Al_Alguire
Las Vegas
Its a LOT of work and you will have as much money as a sheet metal intake when you are done. I talked to "the man" about it a few weeks ago. I thought you guys could run sheet metal stuff?
Re: B1 question
[Re: e85mope]
#2698195
09/16/19 07:38 PM
09/16/19 07:38 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
572 14:1 nss motor on One Ethanol. Oneethanol.com I had an APD 1250’built for my B1 headed 572 but did some wheeling dealing with them for an 1150 alcohol carb which I should receive soon if I decide to Bracket Race this car.
Re: B1 question
[Re: Sammy]
#2698218
09/16/19 08:49 PM
09/16/19 08:49 PM
Al_Alguire
Las Vegas
Sheetmetal intake is $3500.00+ $$ Adapter plates is your only option to use a Indy Crossram with B1 heads. I dont think anyone is making them anymore. By the time you are done you will have that in it, unless you own a machine shop can weld cast aluminum, have some mad skillzzz and don't value your time. Then you will still have a compromise on the intake, way more so than sheet metal. But it CAN be done and there are a couple out there and they paid dearly. B1 head and Indy head share NOTHING in common other than bolt pattern on the block. The intake bolt spacing is different as is the intake face angle between the two heads. Not to mention port size and shape.
Re: B1 question
[Re: fbs63]
#2698413
09/17/19 11:49 AM
09/17/19 11:49 AM
Al_Alguire
Las Vegas
I believe it depends on which NSS class. The FX classes allow for sheet metal stuff, at least NMCA wise. I believe that's where the OP is looking to run.
Re: B1 question
[Re: fbs63]
#2698536
09/17/19 06:41 PM
09/17/19 06:41 PM
Posts: 682 COLUMBUS, OH
Whompin_Wedge
COLUMBUS, OH
IIRC the rules are the plenum can be sheetmetal but the runners have to be cast. At least for NSS. Best Machine makes adapters for B1 to Indy manifolds. I saw a cast B1 tunnel run for sale on one of the Mopar Facebook pages. Yep, Chuck makes adapters for this. Casey FJ
Re: B1 question
[Re: e85mope]
#2698931
09/19/19 10:38 AM
09/19/19 10:38 AM
Posts: 1,824 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
What happened to Orig poster? I thought he was "thinking about" switching to a B1? I'am putting together a B1 for NSS. It ought to be interesting to say the least. I have a sheet metal intake now, but would rather run the indy inline cross ram. BTW.. If anyone is looking for Indy 3x intake, comp 829 lifters, or rods and pistons for a 572, check the race parts for sale section. Good luck finding a set. Those adapters are like gold now.
Re: B1 question
[Re: Sammy]
#2698971
09/19/19 01:04 PM
09/19/19 01:04 PM
Posts: 54 lansing mi.
e85mope
lansing mi.
What happened to Orig poster? I thought he was "thinking about" switching to a B1? I'am putting together a B1 for NSS. It ought to be interesting to say the least. I have a sheet metal intake now, but would rather run the indy inline cross ram. BTW.. If anyone is looking for Indy 3x intake, comp 829 lifters, or rods and pistons for a 572, check the race parts for sale section. Good luck finding a set. Those adapters are like gold now. I'm starting to find that out. I may just end up making my own.
Re: B1 question
[Re: e85mope]
#2698977
09/19/19 01:37 PM
09/19/19 01:37 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
What happened to Orig poster? I thought he was "thinking about" switching to a B1? I'am putting together a B1 for NSS. It ought to be interesting to say the least. I have a sheet metal intake now, but would rather run the indy inline cross ram. BTW.. If anyone is looking for Indy 3x intake, comp 829 lifters, or rods and pistons for a 572, check the race parts for sale section. Good luck finding a set. Those adapters are like gold now. I'm starting to find that out. I may just end up making my own. Not sure he can help you but give Tom a call. http://www.hemphillracingengines.com/
Re: B1 question
[Re: e85mope]
#2698990
09/19/19 02:33 PM
09/19/19 02:33 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I just left Tom a message. Thanks for the referance Hope it helps. I’ve known and raced with Tom for over 40 years. He even has on his website that he makes different spacers. Tell him John Cadamore said hi.
Re: B1 question
[Re: e85mope]
#2700139
09/23/19 01:27 PM
09/23/19 01:27 PM
Al_Alguire
Las Vegas
[quote=e85mope][quote=HardcoreB]
Good luck finding a set. Those adapters are like gold now. I'm starting to find that out. I may just end up making my own. Like I said earlier......
