Flywheel Dust Cover #2694741
09/05/19 05:41 PM
09/05/19 05:41 PM
Milan Ohio
ct440rod Offline OP
ct440rod  Offline OP
Milan Ohio
What where the correct bolts to hold the flywheel cover to a to 70 challenger big block. . looks like 1/4 20 but I was wonder about washer size and was washer one piece with nut or did washer turn. .
thanks
Re: Flywheel Dust Cover [Re: ct440rod] #2694763
09/05/19 06:45 PM
09/05/19 06:45 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
On mine, it uses the black oxide bolt heads with spinning washers that are just a bit larger OD than the hexes.
A bit tight between the washers and the lip of the cover, as I recall, but they clear.
Re: Flywheel Dust Cover [Re: ct440rod] #2694874
09/06/19 07:46 AM
09/06/19 07:46 AM
Mass
charge70 Offline
charge70  Offline
Mass
thanks
In the past I have used old big block engine oil pan bolts.They may not be 100% correct but work fine.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
