Page 1 of 4 1 2 3 4
Won't start, I am throwing in the towel #2693252
08/31/19 08:11 PM
08/31/19 08:11 PM
irvine, california
stephen Offline OP
stephen  Offline OP
irvine, california
hi guys, need some serious help here.
1967 plymouth fury III 383.
one day driving down the road, a loud backfire then engine died, wouldn't start. so I had it towed home and have replaced the following since:
new distributor, new ignition coil, new fuel pump, new fuel filter.
still wont start. but I can feel it really WANT TO start, so close..... yet.....
I used the spark tester, has sparks to the plugs.
what am I missing? what else should I try?
please help.
Re: Won't start, I am throwing in the towel [Re: stephen] #2693255
08/31/19 08:14 PM
08/31/19 08:14 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
If the motor has a lot of miles on it I would guess the timing chain skipped a tooth.
Re: Won't start, I am throwing in the towel [Re: slantzilla] #2693256
08/31/19 08:17 PM
08/31/19 08:17 PM
nowhere
Sniper Online content
Sniper  Online Content
nowhere
That was my first thought as well.
Re: Won't start, I am throwing in the towel [Re: Sniper] #2693258
08/31/19 08:25 PM
08/31/19 08:25 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Mine too, happened to me with a '68 440.
Re: Won't start, I am throwing in the towel [Re: Alaskan_TA] #2693260
08/31/19 08:28 PM
08/31/19 08:28 PM
irvine, california
stephen Offline OP
stephen  Offline OP
irvine, california
thanks guys.
is it a difficult job to adjust timing?
is there a link for the procedure?
thanks
Re: Won't start, I am throwing in the towel [Re: stephen] #2693261
08/31/19 08:32 PM
08/31/19 08:32 PM
md
mopars4ever Offline
mopars4ever  Offline
md
skipped a tooth means time for a new timing chain and gears
Re: Won't start, I am throwing in the towel [Re: mopars4ever] #2693262
08/31/19 08:33 PM
08/31/19 08:33 PM
nowhere
nowhere
If you are lucky, if not it means bent valves.
Re: Won't start, I am throwing in the towel [Re: Sniper] #2693263
08/31/19 08:39 PM
08/31/19 08:39 PM
irvine, california
stephen Offline OP
stephen  Offline OP
irvine, california
please tell me what I should do first, second.....
thanks
Re: Won't start, I am throwing in the towel [Re: stephen] #2693264
08/31/19 08:52 PM
08/31/19 08:52 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Find someone locally that can help. This is not a job for a brand new car guy. You can fumble through it and maybe figure it out but this isn't as simple as changing a few external parts.
Re: Won't start, I am throwing in the towel [Re: stephen] #2693270
08/31/19 09:14 PM
08/31/19 09:14 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Remove your distributor cap so you can see the rotor.
Get a breaker bar & find a socket the right size for the harmonic balancer bolt inside the crank pulley.
Rotate engine just until you see the rotor end move.
Then change directions, if you can turn the engine several degrees before the rotor starts to swing back, your timing chain and / or pulleys have worn to excess.
Re: Won't start, I am throwing in the towel [Re: Alaskan_TA] #2693271
08/31/19 09:16 PM
08/31/19 09:16 PM
irvine, california
stephen Offline OP
stephen  Offline OP
irvine, california
thanks, exactly the kind of help I am looking for.
I will do it tomorrow and report back.
Re: Won't start, I am throwing in the towel [Re: stephen] #2693278
08/31/19 10:08 PM
08/31/19 10:08 PM
New Jersey
P
Powerflow Offline
Powerflow  Offline
P
New Jersey
Another way to check for a skipped timing chain is to pull out the coil wire, take off the air filter, and have a helper crank the engine. Hold your hand over the carburetor throat while cranking. You should feel only suction at the carb. if you get puffs of air pushing up out of the carb it's a timing chain issue.
Re: Won't start, I am throwing in the towel [Re: Powerflow] #2693288
08/31/19 10:51 PM
08/31/19 10:51 PM
You might do a compression test, easy & non invasive. The socket for the crank priorly mentioned is 1&1/4". As said I would ask for some help. Holler how it turns out.
Re: Won't start, I am throwing in the towel [Re: slantzilla] #2693299
08/31/19 11:11 PM
08/31/19 11:11 PM
San Angelo, Texas, U.S.A.
1968RR Offline
1968RR  Offline
If your timing chain jumped, you may start losing teeth on your torque converter/flywheel (if you have an automatic transmission) when your engine backfires. If this starts to happen don't waste your time and assume that it is a starter issue. Unfortunately, I'm speaking from experience...
Good luck.
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
Re: Won't start, I am throwing in the towel [Re: 1968RR] #2693316
09/01/19 12:14 AM
09/01/19 12:14 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Even a low compression 383 is an interference engine. Found that out the hard way (my brother was driving the car at the time). I was in a back brace following a broken back, BUT I replaced the timing set AND the bent pushrods (15 of 16 were bent, but all were replaced). Valves were clearly bent, but we never dug further into it. Dad traded it in later that summer (1980).
Re: Won't start, I am throwing in the towel [Re: Alaskan_TA] #2693325
09/01/19 12:54 AM
09/01/19 12:54 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Originally Posted by Alaskan_TA
Remove your distributor cap so you can see the rotor. Get a breaker bar & find a socket the right size for the harmonic balancer bolt inside the crank pulley. Rotate engine just until you see the rotor end move. Then change directions, if you can turn the engine several degrees before the rotor starts to swing back, your timing chain and / or pulleys have worn to excess.
Best 1st move to make IF you KNOW that motor has many miles on it, OR even if you don't.
A true roller chain/gear would have to wear alot before skipping. Those plastic coated teeth gears, not so much.
When those plastic pcs. break off the gears, they usually fall into the oil pan.
Drain some oil & see what's there.
Re: Won't start, I am throwing in the towel [Re: Sniper] #2693378
09/01/19 09:58 AM
09/01/19 09:58 AM
ky.
K
kenworth_goose Offline
K
ky.
Skipping one tooth will not make it not run! I would say it has jumped timing but not just one tooth.
Re: Won't start, I am throwing in the towel [Re: kenworth_goose] #2693381
09/01/19 10:11 AM
09/01/19 10:11 AM
nowhere
nowhere
One tooth, two teeth, ten teeth, point is it needs to be checked and fixed regardless of the number of teeth it may have jumped.
Re: Won't start, I am throwing in the towel [Re: Sniper] #2693416
09/01/19 11:18 AM
09/01/19 11:18 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Find yourself a Chiltons manual for that year and follow the diagnostic guide. Here’s one that I found on the net.
https://www.ifitjams.com/starting.htm
Abe Lincoln
Re: Won't start, I am throwing in the towel [Re: stephen] #2693455
09/01/19 03:21 PM
09/01/19 03:21 PM
IMGTX Offline
IMGTX  Offline
If the timing chain is OK check the carburetor for fuel problems.
Backfires can bust power valves and bend plates that may prevent starting. Most backfires do not cause problems, some do.
Additionally if it isn't the timing chain you need to find the source of the backfire. Probably a misfiring plug cause by bad wires, cap, or plug.
Page 1 of 4 1 2 3 4
