Won't start, I am throwing in the towel
#2693252
08/31/19 08:11 PM
08/31/19 08:11 PM
Posts: 16 irvine, california
stephen
irvine, california
hi guys, need some serious help here.
1967 plymouth fury III 383.
one day driving down the road, a loud backfire then engine died, wouldn't start. so I had it towed home and have replaced the following since:
new distributor, new ignition coil, new fuel pump, new fuel filter.
still wont start. but I can feel it really WANT TO start, so close..... yet.....
I used the spark tester, has sparks to the plugs.
what am I missing? what else should I try?
please help.
Re: Won't start, I am throwing in the towel
[Re: stephen]
#2693255
08/31/19 08:14 PM
08/31/19 08:14 PM
Posts: 20,212 Park Forest, IL
slantzilla
Park Forest, IL
If the motor has a lot of miles on it I would guess the timing chain skipped a tooth.
[Re: slantzilla]
#2693256
08/31/19 08:17 PM
08/31/19 08:17 PM
Posts: 6,324 nowhere
Sniper
nowhere
If the motor has a lot of miles on it I would guess the timing chain skipped a tooth. That was my first thought as well.
[Re: mopars4ever]
#2693262
08/31/19 08:33 PM
08/31/19 08:33 PM
Sniper
nowhere
skipped a tooth means time for a new timing chain and gears If you are lucky, if not it means bent valves.
[Re: Powerflow]
#2693288
08/31/19 10:51 PM
08/31/19 10:51 PM
RapidRobert
You might do a compression test, easy & non invasive. The socket for the crank priorly mentioned is 1&1/4". As said I would ask for some help. Holler how it turns out.
[Re: slantzilla]
#2693299
08/31/19 11:11 PM
08/31/19 11:11 PM
Posts: 1,943 San Angelo, Texas, U.S.A.
1968RR
If your timing chain jumped, you may start losing teeth on your torque converter/flywheel (if you have an automatic transmission) when your engine backfires. If this starts to happen don't waste your time and assume that it is a starter issue. Unfortunately, I'm speaking from experience... Good luck.
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
[Re: Alaskan_TA]
#2693325
09/01/19 12:54 AM
09/01/19 12:54 AM
Posts: 1,757 Phila
PhillyRag
Phila
Remove your distributor cap so you can see the rotor. Get a breaker bar & find a socket the right size for the harmonic balancer bolt inside the crank pulley. Rotate engine just until you see the rotor end move. Then change directions, if you can turn the engine several degrees before the rotor starts to swing back, your timing chain and / or pulleys have worn to excess. Best 1st move to make IF you KNOW that motor has many miles on it, OR even if you don't. A true roller chain/gear would have to wear alot before skipping. Those plastic coated teeth gears, not so much. When those plastic pcs. break off the gears, they usually fall into the oil pan. Drain some oil & see what's there.
[Re: Sniper]
#2693378
09/01/19 09:58 AM
09/01/19 09:58 AM
Posts: 2,046 ky.
kenworth_goose
ky.
If the motor has a lot of miles on it I would guess the timing chain skipped a tooth. That was my first thought as well. Skipping one tooth will not make it not run! I would say it has jumped timing but not just one tooth.
[Re: kenworth_goose]
#2693381
09/01/19 10:11 AM
09/01/19 10:11 AM
Sniper
nowhere
If the motor has a lot of miles on it I would guess the timing chain skipped a tooth. That was my first thought as well. Skipping one tooth will not make it not run! I would say it has jumped timing but not just one tooth. One tooth, two teeth, ten teeth, point is it needs to be checked and fixed regardless of the number of teeth it may have jumped.
