New Product: 68-up A-Body Fuel tanks without the side to side recess in the bottom
I've got a batch of the 3 variants of 68-up A-Body tanks that are done without the side to side recess in the bottom that was meant for the 67 and earlier cars where the strap was going from side to side. Prior to these, all A-Body reproduction tanks were using the same bottom half that had a bottom facing recess that ran from side to side. The patterning of the new one is based on the 70-71 ECS and regular 71-76 tanks where there's a small circular recess as well. The circular recess wasn't present on the 68-70 tank, so it's not fully correct for that one, but much better nonetheless without the side to side recess. The new tanks can be found
HERE ... All three types are in stock and running $139.95.
Thanks to Scott for pushing for these!
