New Product: 68-up A-Body Fuel Tanks w/o side to side recess #2692786
08/30/19 02:56 AM
08/30/19 02:56 AM
Colorado
jsbrown Offline OP
jsbrown  Offline OP
Colorado
New Product: 68-up A-Body Fuel tanks without the side to side recess in the bottom
I've got a batch of the 3 variants of 68-up A-Body tanks that are done without the side to side recess in the bottom that was meant for the 67 and earlier cars where the strap was going from side to side. Prior to these, all A-Body reproduction tanks were using the same bottom half that had a bottom facing recess that ran from side to side. The patterning of the new one is based on the 70-71 ECS and regular 71-76 tanks where there's a small circular recess as well. The circular recess wasn't present on the 68-70 tank, so it's not fully correct for that one, but much better nonetheless without the side to side recess. The new tanks can be found HERE ... All three types are in stock and running $139.95.
Thanks to Scott for pushing for these!
Re: New Product: 68-up A-Body Fuel Tanks w/o side to side recess [Re: jsbrown] #2692787
08/30/19 03:30 AM
08/30/19 03:30 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Looks nice. What are they...16 gallon or 18 ?
Re: New Product: 68-up A-Body Fuel Tanks w/o side to side recess [Re: Kern Dog] #2692804
08/30/19 08:30 AM
08/30/19 08:30 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Sounds good! It is about time the generic tank was replaced!
JB Rhinehart, Realist
A-Body's RULE!
Re: New Product: 68-up A-Body Fuel Tanks w/o side to side recess [Re: Kern Dog] #2692860
08/30/19 11:35 AM
08/30/19 11:35 AM
Colorado
jsbrown Offline OP
jsbrown  Offline OP
Colorado
Hi,
They're spec'd as a 16.
Jeff
Re: New Product: 68-up A-Body Fuel Tanks w/o side to side recess [Re: jsbrown] #2692908
08/30/19 01:41 PM
08/30/19 01:41 PM
cheshire, ct
davesmopars Offline
davesmopars  Offline
cheshire, ct
This is awesome!!
Did you fix the 70 tank issue with the filler hole in the wrong spot? The filler hole should be in the same spot as the 71 and up tanks, all you need is a 72 tank without the nipple to make it correct for 70.
It is not the same as 68 and 69 tanks
Keeper of the 440 M code Cuda registry
mcodecuda@yahoo.com
Re: New Product: 68-up A-Body Fuel Tanks w/o side to side recess [Re: davesmopars] #2692915
08/30/19 02:03 PM
08/30/19 02:03 PM
Colorado
jsbrown Offline OP
jsbrown  Offline OP
Colorado
Thank you for the info!! This change was only to the bottom half. I’ll look into what you’ve asked about. I appreciate the feedback!
Re: New Product: 68-up A-Body Fuel Tanks w/o side to side recess [Re: jsbrown] #2693053
08/30/19 11:37 PM
08/30/19 11:37 PM
cheshire, ct
davesmopars Offline
davesmopars  Offline
cheshire, ct
Everyone advertises the 1970 gas tank wrong. It's a one year only gas tank.
Here is a picture of a 70 tank and a 68 - 69 tank, you can see the filler holes is not in the same location.
I have a 72 tank in my 70 duster. I just cap the nipple. I would like to but the correct tank in it.
mcodecuda@yahoo.com
Re: New Product: 68-up A-Body Fuel Tanks w/o side to side recess [Re: davesmopars] #2916810
04/30/21 01:56 AM
04/30/21 01:56 AM
Land of 10,000 Lakes
44D6PAKCUDA Offline
44D6PAKCUDA  Offline
JSBrown is out of the 1970-71 4 vent tanks.Does anyone else know of a vendor selling the new tooling tanks?
