King Bearing Question #2689140
08/18/19 06:17 PM
08/18/19 06:17 PM
P
Porter67 Offline OP
Porter67  Offline OP
P
Hi,
So would a .010X rod bearing for extra oil clearance be .009 right? So why did I get an .011 ?
Sounds like a simple question but I will explain after I get an answer. But im trying to figure out why a new set of bearings have 15 marked 10X and one 011? Did I get a jacked bearing in the mix or one from a diff batch? It seems I got jacked.
Thanks.
Re: King Bearing Question [Re: Porter67] #2689150
08/18/19 06:47 PM
08/18/19 06:47 PM
Sullivan, IN
Mopar Sam Offline
Mopar Sam  Offline
Sullivan, IN
I would mic it to know for sure.
Re: King Bearing Question [Re: Porter67] #2689151
08/18/19 06:52 PM
08/18/19 06:52 PM
I measure every rod and main journal first and then measure the rods and main bearing in the block and rods torque down to see how much oil clearance I actually have scope Usually it is not enough with regular under size bearings but I like really loose oil clearances like .0040+ on the mains and at least .0030+ on the rods twocents Take nothing for granite tsk check all of them scope
Let us know what you find on that one marked .0110 work
Re: King Bearing Question [Re: Cab_Burge] #2689166
08/18/19 07:32 PM
08/18/19 07:32 PM
P
Porter67 Offline OP
Porter67  Offline OP
P
If these were two matched sets there would be .002 diff between the two, .009 to .011 and the shell marked .011 is .001 thicker then the shell marked .010X
So I got one shell for a .011 set and 15 shells for the .009 set.
Wonderful.
Re: King Bearing Question [Re: Cab_Burge] #2689278
08/19/19 06:48 AM
08/19/19 06:48 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I like King main bearings but not so on the rods. The tang for locating the bearing in the rod was off on two sets and it would not center the bearing. It was actually sticking past the side of the rod on several. I had to remove part of the tab to center the bearing. Like cab says, check every bearing clearance. I like a dial bore guage best. It is cheap insurance. I also like to size my rods AFTER I get the crank turned. That way you can have the rod clearance set to each journal perfectly. A good shop will do that for you.
Re: King Bearing Question [Re: fastmark] #2689314
08/19/19 09:49 AM
08/19/19 09:49 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
It doesn't matter what the crank size is, you size the rod to spec. The bearing is made to work in that size hole. Then you buy under/oversize bearings to get the clearance where you want it.
2011 Drag Pak Challenger
Re: King Bearing Question [Re: rickseeman] #2690076
08/21/19 05:04 PM
08/21/19 05:04 PM
P
Porter67 Offline OP
Porter67  Offline OP
P
Just to follow up on this, I emailed the seller and King Bearigs, KB told me to go through the dealer and even though I had bought them three months ago and just got to using them they said it was an error on there part (KB) and have me a new set of bearings on the way and a call tag for the jacked set.
So other then a bit of grief, im not out the $70. So props to King Bearings for standing behind there product.
