Hi,
So would a .010X rod bearing for extra oil clearance be .009 right? So why did I get an .011 ?
Sounds like a simple question but I will explain after I get an answer. But im trying to figure out why a new set of bearings have 15 marked 10X and one 011? Did I get a jacked bearing in the mix or one from a diff batch? It seems I got jacked.
Thanks.
