Ready to push it off a cliff..... car wont start. #268789
03/27/09 09:16 PM
03/27/09 09:16 PM
Tomorrow.
Damned67 Offline OP
Damned67  Offline OP
Tomorrow.
Always seems to be something.
Finally, after more years than one can imagine, I was looking forward to actually DRIVING my car today. I really was. Of course, it now won't start, and I can't fault it.
There seems to be spark (pull a plug, crank engine, plug sparks), and there's definitely fuel.
If I follow the MSD instructions, and jump the green and violet wires, removal of the 'jump' will create a spark at the coil wire.
If I've ever had a 'no start' issue, it's been to do with a lack of either fuel or spark. This time I have both, so I'm lost...... And ready to hit it with a hammer. A large hammer.
Where to from here?
Re: Ready to push it off a cliff..... car wont start. [Re: Damned67] #268790
03/27/09 09:33 PM
03/27/09 09:33 PM
St. Charles, MO
wingman Online happy
Uncreative Title
wingman  Online Happy
Uncreative Title
St. Charles, MO
Do you have the MSD red wire hooked up properly? You need to attach it so it is hot both in "start" and "run". Sounds like you may only have the "start" wire hooked up.
If you hooked up your MSD according to the instructions it doesn't mention this. It has drove many a mopar guy crazy. DAMHIK
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: Ready to push it off a cliff..... car wont start. [Re: wingman] #268791
03/27/09 09:51 PM
03/27/09 09:51 PM
Montana
P
Posest Offline
Posest  Offline
P
Montana
Done the same thing. Hook both wires to a constant hot and try it. If it starts then you are on a cranking only hot wire.
Re: Ready to push it off a cliff..... car wont start. [Re: Posest] #268792
03/27/09 09:53 PM
03/27/09 09:53 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Walk away for a little while. Then try some ether. It's easy to flood them with older 10%ethanol fuel. If you have spark, compression, and fuel, it's something easy. Just take a break and come back with a clear head.
Re: Ready to push it off a cliff..... car wont start. [Re: wingman] #268793
03/27/09 09:55 PM
03/27/09 09:55 PM
Tomorrow.
Damned67 Offline OP
Damned67  Offline OP
Tomorrow.
I'm pretty sure the MSD is wired up correctly as it has run in the past without issue.
The car won't even fire off at this stage.
The only thing I can think of is perhaps that the spark is 'weak', but have no idea how to test/measure that.
Re: Ready to push it off a cliff..... car wont start. [Re: moper] #268794
03/27/09 09:57 PM
03/27/09 09:57 PM
Tomorrow.
Damned67 Offline OP
Damned67  Offline OP
Tomorrow.
That was actually my first guess, so I cranked and cranked to clear out any excess fuel.... no luck.
Re: Ready to push it off a cliff..... car wont start. [Re: Damned67] #268795
03/27/09 09:59 PM
03/27/09 09:59 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
thats why i suggested the ether. For some reason i don't have good luck trying to clear them after they flood with this fuel. but a shot of ether and it will start right up and clears out.
Re: Ready to push it off a cliff..... car wont start. [Re: Damned67] #268796
03/27/09 10:12 PM
03/27/09 10:12 PM
Bridgeport, WV
Michael Offline
Michael  Offline
Bridgeport, WV
Make sure the battery is fully charged.
Re: Ready to push it off a cliff..... car wont start. [Re: Michael] #268797
03/27/09 10:27 PM
03/27/09 10:27 PM
Tomorrow.
Damned67 Offline OP
Damned67  Offline OP
Tomorrow.
Battery is/was charged. It started to run down with all the cranking, so I even tried to jump it off another car.....
Re: Ready to push it off a cliff..... car wont start. [Re: Damned67] #268798
03/27/09 11:11 PM
03/27/09 11:11 PM
calif
cupcake Offline
cupcake  Offline
calif
its the way the msd is wired thats wrong just went through that.car would not start.crank it would have spark let off key no spark.this thing let out the loudest backfire i ever herd dont no how the mufflers were still there raw fuel from crankin on it.u need ign 1 & ign 2 hooked together dogg
Re: Ready to push it off a cliff..... car wont start. [Re: Damned67] #268799
03/27/09 11:15 PM
03/27/09 11:15 PM
fully charged battery, new plugs, healthy shot of ether starting fluid. And the dist timing hasn't been changed while trying to get it started this time?.
Re: Ready to push it off a cliff..... car wont start. [Re: RapidRobert] #268800
03/27/09 11:19 PM
03/27/09 11:19 PM
Tomorrow.
Damned67 Offline OP
Damned67  Offline OP
Tomorrow.
Distributor hasn't been touched, so timing should be good.
I'm heading out to the store to see if I can find some ether (have never seen it over here before.... so fingers crossed).
Re: Ready to push it off a cliff..... car wont start. [Re: Damned67] #268801
03/27/09 11:23 PM
03/27/09 11:23 PM
calif
cupcake Offline
cupcake  Offline
calif
yes that eather should realy let out a bang u will think it 4th july big time
Re: Ready to push it off a cliff..... car wont start. [Re: cupcake] #268802
03/27/09 11:25 PM
03/27/09 11:25 PM
calif
cupcake Offline
cupcake  Offline
calif
is it msd dist & box?????
Re: Ready to push it off a cliff..... car wont start. [Re: Damned67] #268803
03/27/09 11:34 PM
03/27/09 11:34 PM
Alabama
BigMoneyLewis Offline
Alabama
How long has it been sitting? If it has sat more than 3 or 4 months, you may need to pour a small amount of gas down the carb . It should fire up and run for at least 3 or 4 seconds , until that fuel burns out. At least that way you know the problem is not the electrical, and you can focus on the carb / fuel pump .
You said it's getting fuel though ? This means you looked inside the carb while working the throttle linkage , and actually saw a good stream of gas squirting into the carb. Correct ?
If you think you are indeed getting fuel, and may have flooded it, hold the accelerator pedal to the floor while cranking (do not pump) .
If you prime the carb with a little gas, and it does not at least fire up and run 2 or 3 seconds ,
then I'd say you need to look for a spark problem , but right now I would lean toward needing a new fuel pump, or rebuild the carb if it has sat uncranked for more than a few months.
Greg
Wards Classic Car Radio Repair Specializing in restoration and sales of Mopar A B E body radios
We can restore YOUR radio usually in less than 7 days
Visit our NEW website..
http://www.wardsclassiccarradiorepair.com
gregward@mchsi.com
phone 256-852-0955
gregward@mchsi.com phone 256-852-0955
Re: Ready to push it off a cliff..... car wont start. [Re: BigMoneyLewis] #268804
03/27/09 11:43 PM
03/27/09 11:43 PM
Tomorrow.
Damned67 Offline OP
Damned67  Offline OP
Tomorrow.
Car ran last week, and no wiring has been changed.
Definitely getting gas, as verified from watching it squirt.
Also tried priming it with gas directly.
Also cranked it with the throttle wide open in case it was flooded.
Just got home from the parts store.... A healthy squirt of ether didn't help.
I'm going to pull the plugs out and have a look right now.
Thanks for all the help so far.
Re: Ready to push it off a cliff..... car wont start. [Re: Damned67] #268805
03/27/09 11:47 PM
03/27/09 11:47 PM
calif
cupcake Offline
cupcake  Offline
calif
pull plugs spin it over get all that crap out it then fix the wireing
Re: Ready to push it off a cliff..... car wont start. [Re: cupcake] #268806
03/27/09 11:56 PM
03/27/09 11:56 PM
Colorado
CuriousYella70 Offline
Colorado
Doubt this is it -- but I had the same issue that you are having with my Duster -- ran one week and the next I couldnt get anything to work right. I had spark, timing, everything was the same, I pulled the plugs and realized a few of them were burned up and only after a few months of mild driving so pull the plugs, maybe you have a few bad ones?
Re: Ready to push it off a cliff..... car wont start. [Re: CuriousYella70] #268807
03/28/09 12:11 AM
03/28/09 12:11 AM
Tomorrow.
Damned67 Offline OP
Damned67  Offline OP
Tomorrow.
Pulled the plugs. They're all black and wet.
The reason the car had been sitting for so long (finally 'fixed' last week), was due to an off-idle rich condition, so I'm not surprised that the plugs are fouled.
I'll give 'em a bit of a clean, and see what happens from there.
Re: Ready to push it off a cliff..... car wont start. [Re: Damned67] #268808
03/28/09 12:16 AM
03/28/09 12:16 AM
Hurry, it's past my bedtime & I'll sleep better knowing that it started for you.
