Ready to push it off a cliff..... car wont start.
#268789
03/27/09 09:16 PM
03/27/09 09:16 PM
Posts: 2,309 Tomorrow.
Damned67
Tomorrow.
Always seems to be something. Finally, after more years than one can imagine, I was looking forward to actually DRIVING my car today. I really was. Of course, it now won't start, and I can't fault it. There seems to be spark (pull a plug, crank engine, plug sparks), and there's definitely fuel. If I follow the MSD instructions, and jump the green and violet wires, removal of the 'jump' will create a spark at the coil wire. If I've ever had a 'no start' issue, it's been to do with a lack of either fuel or spark. This time I have both, so I'm lost...... And ready to hit it with a hammer. A large hammer.
Where to from here?
Re: Ready to push it off a cliff..... car wont start.
[Re: Damned67]
#268790
03/27/09 09:33 PM
03/27/09 09:33 PM
Posts: 3,380 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
Do you have the MSD red wire hooked up properly? You need to attach it so it is hot both in "start" and "run". Sounds like you may only have the "start" wire hooked up.
If you hooked up your MSD according to the instructions it doesn't mention this. It has drove many a mopar guy crazy. DAMHIK
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
[Re: Posest]
#268792
03/27/09 09:53 PM
03/27/09 09:53 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Walk away for a little while. Then try some ether. It's easy to flood them with older 10%ethanol fuel. If you have spark, compression, and fuel, it's something easy. Just take a break and come back with a clear head.
[Re: Damned67]
#268795
03/27/09 09:59 PM
03/27/09 09:59 PM
moper
Columbia, CT
thats why i suggested the ether. For some reason i don't have good luck trying to clear them after they flood with this fuel. but a shot of ether and it will start right up and clears out.
[Re: Damned67]
#268799
03/27/09 11:15 PM
03/27/09 11:15 PM
RapidRobert
fully charged battery, new plugs, healthy shot of ether starting fluid. And the dist timing hasn't been changed while trying to get it started this time?.
[Re: Damned67]
#268803
03/27/09 11:34 PM
03/27/09 11:34 PM
Posts: 4,247 Alabama
BigMoneyLewis
Alabama
How long has it been sitting? If it has sat more than 3 or 4 months, you may need to pour a small amount of gas down the carb . It should fire up and run for at least 3 or 4 seconds , until that fuel burns out. At least that way you know the problem is not the electrical, and you can focus on the carb / fuel pump . You said it's getting fuel though ? This means you looked inside the carb while working the throttle linkage , and actually saw a good stream of gas squirting into the carb. Correct ? If you think you are indeed getting fuel, and may have flooded it, hold the accelerator pedal to the floor while cranking (do not pump) . If you prime the carb with a little gas, and it does not at least fire up and run 2 or 3 seconds , then I'd say you need to look for a spark problem , but right now I would lean toward needing a new fuel pump, or rebuild the carb if it has sat uncranked for more than a few months. Greg Wards Classic Car Radio Repair Specializing in restoration and sales of Mopar A B E body radios We can restore YOUR radio usually in less than 7 days Visit our NEW website.. http://www.wardsclassiccarradiorepair.comgregward@mchsi.comphone 256-852-0955
[Re: BigMoneyLewis]
#268804
03/27/09 11:43 PM
03/27/09 11:43 PM
Damned67
Tomorrow.
Car ran last week, and no wiring has been changed. Definitely getting gas, as verified from watching it squirt. Also tried priming it with gas directly. Also cranked it with the throttle wide open in case it was flooded. Just got home from the parts store.... A healthy squirt of ether didn't help. I'm going to pull the plugs out and have a look right now. Thanks for all the help so far.
[Re: CuriousYella70]
#268807
03/28/09 12:11 AM
03/28/09 12:11 AM
Damned67
Tomorrow.
Pulled the plugs. They're all black and wet. The reason the car had been sitting for so long (finally 'fixed' last week), was due to an off-idle rich condition, so I'm not surprised that the plugs are fouled. I'll give 'em a bit of a clean, and see what happens from there.
