Ebody power window regulator question. #2686740
08/12/19 08:40 AM
08/12/19 08:40 AM
new berlin wisconsin
Mr T2U Online content OP
Mr T2U  Online Content OP
are cuda and challenger power window regulators for converts and HT the same?
my guess is yes.
i no longer have my parts books and vintage crash estimating manuals to verify. their really aren't any on ebay to verify also.
the closest i can find is these listings and they only state cuda/ challenger. no mention of HT/ convert.
repo parts also no mention of HT or convert and also just a listing not a sold one
https://www.ebay.com/itm/1970-74-Ch...Kit-Front-Without-Switches/392199806800?
next 2 are sold listings OEM parts but nothing about HT or convert
https://www.ebay.com/itm/1970-CHALL...ER-WINDOWS-RIGHT-amp-LEFT-/264329550425?
https://www.ebay.com/itm/1970-CHALL...ER-WINDOWS-RIGHT-amp-LEFT-/264329550207?
OPINION?
perception is 90% of reality
Re: Ebody power window regulator question. [Re: Mr T2U] #2686748
08/12/19 08:58 AM
08/12/19 08:58 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
1/4 windows are unique to a convertible
Re: Ebody power window regulator question. [Re: gtx6970] #2686752
08/12/19 09:03 AM
08/12/19 09:03 AM
THANKS for the fast reply.
i know the GLASS is convert/HT only but are the POWER REGULATORS convert/ HT only?
Re: Ebody power window regulator question. [Re: gtx6970] #2686765
08/12/19 09:29 AM
08/12/19 09:29 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Correct but my buddy used H/T quarter regulators in his vert. Didn't seem to be a problem.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Ebody power window regulator question. [Re: moparmarks] #2686896
08/12/19 01:43 PM
08/12/19 01:43 PM
this is what makes me believe they are the same. i would like to know for sure. it's been at least 15 years since i worked on E body window parts. i sold or scrapped all of my window regulator parts i had laying around several years ago. i don't have any for comparison purposes.
i will probably get flamed for this. but in my opinion the regulators are all the same. between ht convert cuda challenger.
yes the cranking parts, handle studs/ arm with gear, are different, but they are just held to the regulator arms by rivets and bolts.but the arm parts that move the window up and down are all the same between all of the E body cars. drill out some rivets, change a couple of parts and you just made a different regulator.
Re: Ebody power window regulator question. [Re: Mr T2U] #2686990
08/12/19 06:50 PM
08/12/19 06:50 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I believe the assist springs are different between the manual and power windows. I broke one on my driver's side power window a few years ago. I used the spring off a manual regulator I had laying around. I can't tell any difference between it and the passenger side with the original spring.
Master, again and still
Re: Ebody power window regulator question. [Re: DaveRS23] #2687504
08/14/19 01:38 AM
08/14/19 01:38 AM
Colorado
spk2go Offline
spk2go  Offline
Colorado
On the power window regulators: the fronts are the same, the 1/4's have a notch cut out to give the glass more clearance on the convertibles.
Re: Ebody power window regulator question. [Re: spk2go] #2687530
08/14/19 07:48 AM
08/14/19 07:48 AM
THANK YOU for the reply.
extreme long shot. by any chance you have a pic of cut out area?
Re: Ebody power window regulator question. [Re: Mr T2U] #2687834
08/14/19 09:01 PM
08/14/19 09:01 PM
Virginia
larry4406 Online content
larry4406  Online Content
Virginia
Here are some pics I have saved from long ago from somewhere here on the net. Kudo's to the original poster whomever you are.
71 Cuda Vert Power Window Assembly - Quarter Regulator.jpgcuda rear power window regulators.jpg71 Cuda Vert Power Window Assembly.JPG
Re: Ebody power window regulator question. [Re: larry4406] #2687836
08/14/19 09:02 PM
08/14/19 09:02 PM
Virginia
Virginia
Few more
e-body vert quarter regulator1.jpge-body vert quarter regulator2.jpge-body vert quarter regulator3.jpg
Re: Ebody power window regulator question. [Re: larry4406] #2687918
08/15/19 07:51 AM
08/15/19 07:51 AM
THANK YOU for the pics
Re: Ebody power window regulator question. [Re: Mr T2U] #2954058
08/15/21 04:41 PM
08/15/21 04:41 PM
NotRussia
2
2fast4yourBrain Offline
Whack top Dodger
Whack top Dodger
2
NotRussia
Anyone have the part numbers for the rears?
I'm told the converts are: 3454907 (LEFT) and 3454908 (RIGHT).
What are the hard top part numbers?
On the regs I'm selling, I see:
3454908 (but it actually looks like a six)
and
2999429
Re: Ebody power window regulator question. [Re: 2fast4yourBrain] #2954063
08/15/21 05:14 PM
08/15/21 05:14 PM
NotRussia
2
Whack top Dodger
Whack top Dodger
2
NotRussia
more pics
