header gaskets ? #2687548
08/14/19 08:37 AM
08/14/19 08:37 AM
Chicago land, IL
dafixr Offline OP
dafixr  Offline OP
Chicago land, IL
What is the best header gasket to use. Street use
Have copper now but leaks even with high temp silicone.
Headers are cut in between to float
Re: header gaskets ? [Re: dafixr] #2687557
08/14/19 08:53 AM
08/14/19 08:53 AM
Washington
madscientist Offline
Washington
Remflex. They'll seal almost anything.
Re: header gaskets ? [Re: dafixr] #2687559
08/14/19 08:53 AM
08/14/19 08:53 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Remflex gaskets works for me. My only problem with them is they can tear when removing them after use.
Re: header gaskets ? [Re: mopars4ever] #2687645
08/14/19 11:36 AM
08/14/19 11:36 AM
Chicago land, IL
dafixr Offline OP
dafixr  Offline OP
Chicago land, IL
Can we get from Jegs or Summit?
Re: header gaskets ? [Re: dafixr] #2687650
08/14/19 11:54 AM
08/14/19 11:54 AM
Mequon, WI
gzig5 Offline
gzig5  Offline
Mequon, WI
You have a computer. You can go on their sites and see if they carry them for your application or call them. Come on man!
Re: header gaskets ? [Re: dafixr] #2687660
08/14/19 12:12 PM
08/14/19 12:12 PM
Cab_Burge Online work
Cab_Burge  Online Work
Sounds like you need to have the header flanges machine flat to seal them up better scope twocents
Re: header gaskets ? [Re: Cab_Burge] #2687662
08/14/19 12:15 PM
08/14/19 12:15 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I've used a body board and 80 grit to knock down the high spots on the flanges before, if its an issue. As mentioned above, Remflex is the only way to go.
Re: header gaskets ? [Re: jbc426] #2687706
08/14/19 01:30 PM
08/14/19 01:30 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Percy's dead soft aluminum has worked great for me
Re: header gaskets ? [Re: madscientist] #2687715
08/14/19 01:48 PM
08/14/19 01:48 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
iagree
Re: header gaskets ? [Re: 451Mopar] #2687731
08/14/19 03:16 PM
08/14/19 03:16 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
Regardless what gasket you use, IF the two mating surfaces are not clean and flat, or else if the threadings are not clean and free of debris, then no gasket will seal properly. Occasional retorquing is advisable due to the weakness and vibrations of tubular headers. Always inspect the surface flanges of the headers -- they are notorious to have flaws and poor surface flatness (at the welds of the tubes into the flange).
Re: header gaskets ? [Re: Mopar Mitch] #2687740
08/14/19 04:01 PM
08/14/19 04:01 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Copper gaskets and copper rtv should cover it unless your sealing surfaces are uneven.
I ink up the flanges and file them in an x-pattern with a wide file until the ink is gone.
Re: header gaskets ? [Re: Neil] #2687749
08/14/19 05:14 PM
08/14/19 05:14 PM
MR_P_BODY Offline
MR_P_BODY  Offline
How thick are the flanges... if 1/4" you could have problems all along... 5/16 can be iffy if not flat.. I
build all my headers with 3/8 flanges and still make sure they are flat after welding
wave
