Re: Universal motor mount kits?
[Re: Lefty]
#268440
03/27/09 02:53 PM
03/27/09 02:53 PM
Posts: 25,783 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Why not scrap the universal tubing crossmember and mount the motor on the square tube suspension/steering crossmember?
[Re: John_Kunkel]
#268441
03/27/09 03:20 PM
03/27/09 03:20 PM
Posts: 6,516 Santa Cruz, California
Lefty
I'm a little worried the angle would be such that the mount would apply a lot of twisting torque because it's so far behind the new cross member. I'll be boxing the frame and adding support plates to the cross member because of the gaps to the frame rails.
Here's a somewhat better pic. The original mm cross member mount bolt holes are actually further back than the pic shows. The weight of the engine would be to the rear of the new cross member by about an inch. Too much twisting torque?
[Re: Lefty]
#268442
03/27/09 03:51 PM
03/27/09 03:51 PM
Posts: 7,992 Escondido, CA. Ron Podsiadly,...
Mopar Ron
The engine (small Chebby) is offset to the passenger side. Yeah, I know... I already told him we need to dump the engine and get a 5.7 Hemi in there.
when will these guys learn that a mopar belongs in a mopar, I don't care how cheap a chevy is, put it in a chevy rant over!!!!!
as far as mounts go I would use the ones from chassis engineering and if you have to, cut loose the rack mounts and aim it a little lower to go under the mount
and talk your friend into putting a mopar in it Ron....
http://www.chassisengineeringinc.com/page30.html
[Re: earlymopar]
#268445
03/28/09 09:10 PM
03/28/09 09:10 PM
Posts: 1,528 Southeast PA
5wndwcpe
Southeast PA
Or box in the frame rails and lose the tubular piece altogether. Affix the motor mounts to the inner frame rail. It looks to me that the surrent crossmember is a little far foward to use for the mounts.
1968 GTX hardtop 1968 Sport Satellite Convertible 383/4spd 1933 Plymouth coupe 2002 Ram 2500 oil burner 4x4 2015 Grand Cherokee 2013 Challenger 1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
