Big Block Head gasket ?? #2679539
07/20/19 07:49 PM
07/20/19 07:49 PM
N.C.
W
wupracing Offline OP
W
N.C.
We have a 499 Indy head engine.On the Head gaskets what is the prefer head gasket. We notice on the Felpro 1009 gasket the water jacket bottom 2 center holes are not cut out on that gasket will this be a problem. I have seen most everybody says use this gasket.
Re: Big Block Head gasket ?? [Re: wupracing] #2679540
07/20/19 07:54 PM
07/20/19 07:54 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I had problems with that gasket on my 505. Never really figured out why but trashed them and have run Cometics ever since. Zero issues since.
'63 Dodge 330
11.19 @ 121 mph
Re: Big Block Head gasket ?? [Re: GY3] #2679541
07/20/19 07:59 PM
07/20/19 07:59 PM
N.C.
W
W
N.C.
What kind of compression did you have also was your street or strip . Mind is Drag race only with around 14.1 comp.
Re: Big Block Head gasket ?? [Re: wupracing] #2679549
07/20/19 08:43 PM
07/20/19 08:43 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
One of the long standing complaints about the Fel-Pro 1009 is how close to the bore the fire ring is. I didn't have any problems with a 4.375" where there was basically no chamfer left at the top of the cylinders and the chambers were small enough to not leave the fire ring exposed anywhere. However, others posted about problems, including torching the tops of the block in between cylinders.
Is there a reason why you're not looking into an MLS head gasket, especially given the CR you have?
Re: Big Block Head gasket ?? [Re: BradH] #2679552
07/20/19 08:50 PM
07/20/19 08:50 PM
birdtracker Online boogie
birdtracker  Online Boogie
https://www.jegs.com/i/Fel-Pro/375/1039/10002/-1
this is what I have in my engine right now. It was recommended to me to use rtv around all the coolant holes both block and heads. Birdtracker
Re: Big Block Head gasket ?? [Re: birdtracker] #2679575
07/20/19 09:57 PM
07/20/19 09:57 PM
N.C.
W
W
N.C.
That gasket is a little thicker than we want.
Re: Big Block Head gasket ?? [Re: BradH] #2679577
07/20/19 10:02 PM
07/20/19 10:02 PM
N.C.
W
W
N.C.
Never try them
It had the SCE copper on it but think they are the wrong ones
Re: Big Block Head gasket ?? [Re: wupracing] #2679689
07/21/19 10:44 AM
07/21/19 10:44 AM
Livermore, CA
Dduster Offline
Dduster  Offline
Livermore, CA
Get Cometics X2. They'll make the thickness You request, yes they are expensive but they work Great. 14:1 compression is not an issue. It will be a little higher along with a couple of other parameters with thinner gaskets so pay attention with the change.
Re: Big Block Head gasket ?? [Re: Dduster] #2679693
07/21/19 10:56 AM
07/21/19 10:56 AM
K
KOS Offline
KOS  Offline
K
cometic for MLS .....Hussey if your going copper they will make what you need for thickness and fast....best in the business.
Re: Big Block Head gasket ?? [Re: wupracing] #2679718
07/21/19 12:00 PM
07/21/19 12:00 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
10.6:1
'63 Dodge 330
11.19 @ 121 mph
Re: Big Block Head gasket ?? [Re: wupracing] #2679884
07/21/19 09:12 PM
07/21/19 09:12 PM
N.C.
W
W
N.C.
One of the question I am asking is about the 2 coolet holes that are block by that gasket will that be a problem.I do know the copper gasket the coolet holes where all open.
Re: Big Block Head gasket ?? [Re: wupracing] #2679894
07/21/19 09:58 PM
07/21/19 09:58 PM
SCE was one of the best gasket company out there when it came to getting custom made copper head gaskets for 3 of my blown hemi motor I built for customers up
They offer 5 or 6 different styles of copper head gaskets also scope
I say this based on past experiences before they where bought, sold again and relocated back east shruggy work
Re: Big Block Head gasket ?? [Re: wupracing] #2679973
07/22/19 04:21 AM
07/22/19 04:21 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Think the holes your talking about are blank on the Indy heads.
1963 Plymouth Max Wedge
1971 Barracuda
Re: Big Block Head gasket ?? [Re: ozymaxwedge] #2679978
07/22/19 06:41 AM
07/22/19 06:41 AM
N.C.
W
W
N.C.
No the Indy heads have the Holes as do the block but the 1009 gasket does not.
Re: Big Block Head gasket ?? [Re: wupracing] #2679979
07/22/19 06:48 AM
07/22/19 06:48 AM
N.C.
W
W
N.C.
Re: Big Block Head gasket ?? [Re: wupracing] #2679997
07/22/19 08:39 AM
07/22/19 08:39 AM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
You will need to drill a hole a 1/4 or 3/8 hole in 1009 in the missing locations - at least that is what I have always have done with them if the head and block have the holes there
Re: Big Block Head gasket ?? [Re: DoubleD] #2680002
07/22/19 08:46 AM
07/22/19 08:46 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
You need a specific deck and head finish to use MLS gaskets. I had a good discussion with Cometic about that and they are quite adamant about it.
Re: Big Block Head gasket ?? [Re: Stanton] #2680054
07/22/19 11:15 AM
07/22/19 11:15 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
At 10:1ish I would just use the garden variety Felpro that comes in their gasket sets. .039 compressed and the bore size is big enough to accommodate the chamfer without overhanging the bore which is the problem with the 1009.
If you need a thinner compressed thickness than .039 I'm not aware of any composites that spec less than that although I know of an instance where a .039 actually compressed to .037 and caused a hydroplane team to fail post race tech.
Depending on what thickness you need, although not recommended a shim gasket might be an option but an MLS is probably your best bet to get the thickness you require.
Kevin
Re: Big Block Head gasket ?? [Re: wupracing] #2680223
07/22/19 07:42 PM
07/22/19 07:42 PM
AndyF Offline
AndyF  Offline
The only gasket I'd use in an engine like that is Cometic. Nothing else. The composite race gasket will work, but it will Brinell the head which ends up costing you money in the long run. Which is why I wouldn't use anything other than Cometic.
Re: Big Block Head gasket ?? [Re: wupracing] #2680254
07/22/19 09:40 PM
07/22/19 09:40 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Ya learn something everyday , thanks .
1971 Barracuda
