Big Block Head gasket ??
#2679539
07/20/19 07:49 PM
07/20/19 07:49 PM
Posts: 488 N.C.
wupracing
N.C.
We have a 499 Indy head engine.On the Head gaskets what is the prefer head gasket. We notice on the Felpro 1009 gasket the water jacket bottom 2 center holes are not cut out on that gasket will this be a problem. I have seen most everybody says use this gasket.
Re: Big Block Head gasket ??
[Re: wupracing]
#2679540
07/20/19 07:54 PM
07/20/19 07:54 PM
Posts: 4,674 Wichita
GY3
Wichita
I had problems with that gasket on my 505. Never really figured out why but trashed them and have run Cometics ever since. Zero issues since.
[Re: wupracing]
#2679718
07/21/19 12:00 PM
07/21/19 12:00 PM
GY3
Wichita
What kind of compression did you have also was your street or strip . Mind is Drag race only with around 14.1 comp. 10.6:1
[Re: wupracing]
#2679973
07/22/19 04:21 AM
07/22/19 04:21 AM
Posts: 1,096 Australia
ozymaxwedge
Australia
One of the question I am asking is about the 2 coolet holes that are block by that gasket will that be a problem.I do know the copper gasket the coolet holes where all open. Think the holes your talking about are blank on the Indy heads.
1963 Plymouth Max Wedge 1971 Barracuda
[Re: ozymaxwedge]
#2679978
07/22/19 06:41 AM
07/22/19 06:41 AM
Posts: 488 N.C.
wupracing
N.C.
One of the question I am asking is about the 2 coolet holes that are block by that gasket will that be a problem.I do know the copper gasket the coolet holes where all open. Think the holes your talking about are blank on the Indy heads. No the Indy heads have the Holes as do the block but the 1009 gasket does not.
[Re: wupracing]
#2680254
07/22/19 09:40 PM
07/22/19 09:40 PM
ozymaxwedge
Australia
One of the question I am asking is about the 2 coolet holes that are block by that gasket will that be a problem.I do know the copper gasket the coolet holes where all open. Think the holes your talking about are blank on the Indy heads. No the Indy heads have the Holes as do the block but the 1009 gasket does not. Ya learn something everyday , thanks .
