cosmoline #267943
03/27/09 04:57 AM
03/27/09 04:57 AM
michigan
70 buzz Offline OP
70 buzz  Offline OP
michigan
going to do my suspension where do you purchase cosmoline from and do they make it in a spray bomb? Is there a color paint match that duplicates the color any suggestions on what to buy? Thanks
Re: cosmoline [Re: 70 buzz] #267944
03/27/09 10:06 AM
03/27/09 10:06 AM
Waterloo Iowa
8
80mirada Offline
80mirada  Offline
Waterloo Iowa
You will probably have to color match it, Cosmoline, is nasty crap. You could also try asking A gun dealer that deals in Surplus rifle, they may know of a source for it, as many nations store firearms,coated in it.
Re: cosmoline [Re: 70 buzz] #267945
03/27/09 10:33 AM
03/27/09 10:33 AM
None
71rm23 Offline
71rm23  Offline
None
70 Buzz- Do a search for it on the net. There has been a post here and members say where they got it from. Can get it in a can and/or a 5 gal bucket for bigger peices.(dont have the thread off hand)
Re: cosmoline [Re: 70 buzz] #267946
03/27/09 11:11 AM
03/27/09 11:11 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
There's a few sources for real Cosmoline, and a few sources for imitations in paint form,....should you require "real" Cosmoline, be aware it will take a few weeks to dry, and it will remain somewhat waxy for it's life on the car,.....a 5 gallon bucket will run around $250, sprays run around $25-$50 for sprayable Cosmoline, ...simulated sprays from $2 to $25
it boils down to how "original" you want your car?, or whats in your budget?, or how durable, or resistant you want your finish?
I offer Real Cosmoline in a sprayable 14 OZ can, enough to do 4-6 sets of lower control arms, depending how "dark" you want the coating,....originaly the arms were hung by the ball joint hole on a conveyor rack, and lowered into a molten Cosmoline vat, leaving a small exposed area of steel around the ball joint hole, the reason was to avoid wax in the hole so that on the assy. line the ball joint didn't spin as the worker assembled it,......with a sprayable Cosmoline you can simulate the dipping by carefully taping off the end to simulate a submersion "plumb line" as if it was hanging on line, runs, drips, sags and discoloration would be the norm along the control arms length in a vertical position
PM me here on Moparts for more info, if your interested?
Re: cosmoline [Re: DAYCLONA] #267947
03/27/09 03:17 PM
03/27/09 03:17 PM
WI
RestoRick Offline
RestoRick  Offline
WI
Re: cosmoline [Re: RestoRick] #267948
03/27/09 05:05 PM
03/27/09 05:05 PM
Texas
E
ef8Cuda340 Offline
ef8Cuda340  Offline
E
Texas
I used CRC SP400 and it worked very well.. You can search the web for it. It comes in 5 gal and paint can sizes. It will remain tacky for a couple of days and color depends on how much you apply.
Re: cosmoline [Re: ef8Cuda340] #267949
03/27/09 05:09 PM
03/27/09 05:09 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
Here is spayable cosmoline, it's on the thin side so it spayable but one can will do a pair of lower a arms. Best part it's around $10, I paid $8 and see it online for $9, a can!! I got mine from a local marine shop who supplied our shop.
Re: cosmoline [Re: rrunner] #267950
03/27/09 05:09 PM
03/27/09 05:09 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
part #
Re: cosmoline [Re: rrunner] #267951
03/27/09 05:13 PM
03/27/09 05:13 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
And heres a arm I did, I didn't sand/bead blast or paint this arm as I'm not looking to restore just preserve a org car. The arms had most of the org coatingon it before I cleaned it off in the parts washer, so the arm was in better than average shape. Next time I will hang the arm and spay it heavy to get the runs as were found from the factory. I have about three spayed coats on this arm. I waited about a 1/2 hour between coats and it will take some time as stated above to cure up good but on my test spays durt wouldn't stick after a few days.
Re: cosmoline [Re: 70 buzz] #267952
03/27/09 06:35 PM
03/27/09 06:35 PM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
From what I've seen using the stuff below, it's a pretty close match.
http://www.eastwoodco.com/jump.jsp?itemID=1117&itemType=PRODUCT
Re: cosmoline [Re: 70Duster440] #267953
03/27/09 07:29 PM
03/27/09 07:29 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Cosmoline spray from the original supplier is at Mcmaster Carr
