Bushed aluminum rods #2678913
07/18/19 11:37 PM
07/18/19 11:37 PM
St.Louis ,Mo.
72sat Offline OP
72sat  Offline OP
St.Louis ,Mo.
Can this be done in a hi-po application. Ford pin, mopar rod
Re: Bushed aluminum rods [Re: 72sat] #2678924
07/19/19 01:20 AM
07/19/19 01:20 AM
If your asking about using a wrist pin bushing in a aluminum rod there is no way I would consider doing that tsk
The expansion rate of aluminum to the wrist pin bushing material will not be the same tsk
In other words your messing with fate asking for a accident, failure, to occur twocents shruggy
Re: Bushed aluminum rods [Re: Cab_Burge] #2679037
07/19/19 11:08 AM
07/19/19 11:08 AM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
I understand what Cab is saying but a few years ago I spoke to both Southland Machine and Keith Black about bushing a set of KB hemi alum rods to reduce the pin size to 1.03. Everyone said no problem and that that rod had ample amount of material. Southland said they would make their own bushings instead of buying off the shelf. Project never came to fruition (needed block and crank) but I wish now it would have.
Re: Bushed aluminum rods [Re: Blucuda413] #2679046
07/19/19 11:19 AM
07/19/19 11:19 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
measure hole size at room temps then stick a rod in the oven, get it hot, and then measure the bore for before and after dimensions. then you can make a decision based on real time information.
Re: Bushed aluminum rods [Re: 72sat] #2679054
07/19/19 11:39 AM
07/19/19 11:39 AM
San Jose Ca.
boatracer572 Online content
boatracer572  Online Content
San Jose Ca.
Absolutely!!! I have done it before with both bronze and aluminum bushings.. twocents
Re: Bushed aluminum rods [Re: 72sat] #2679409
07/20/19 12:33 PM
07/20/19 12:33 PM
Nevada
merpar Offline
merpar  Offline
Nevada
Just have bushings made out of similar aluminum. Give about .002 press fit then hone to size. Do not use bronze or 6061 type aluminum. Expansion rate is much greater. A 7075 aluminum would work. When measuring make sure rod and bushing are at the same temp.
Re: Bushed aluminum rods [Re: merpar] #2679410
07/20/19 12:35 PM
07/20/19 12:35 PM
I stand corrected blush
Thanks to those in the know better than me bow up
