Re: methanol
[Re: dragon]
#2678635
07/18/19 11:51 AM
07/18/19 11:51 AM
Posts: 2,560 S.E. Michigan
cl440
S.E. Michigan
Do you run top end lub with methanol I been told not and told you better Always have. I run top lube and scent. In fact i also run top lube in all my gas cans for my small gas engines also (lawn mower, power washer etc...) Seems to help keep the crud and corrosion out of the fuel bowls when they sit. Smells good while I am mowing so that's a bonus! LOL
Re: methanol
[Re: gregsdart]
#2683991
08/03/19 10:52 AM
08/03/19 10:52 AM
Posts: 2,509 PA
moparacer
PA
I had some issues in the past if there was too much lube added. I ran it without for several years without any issues. Been running lube but thinking of trying it without again.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
Re: methanol
[Re: dart games]
#2684215
08/04/19 01:15 AM
08/04/19 01:15 AM
Posts: 43,200 Bend,OR USA
Cab_Burge
I don't add anything to the pump E85 I race on with right at 15.0 to 1 compression That first motor has over 5 yrs racing on it when I removed it this past winter
