methanol #2677551
07/15/19 10:11 AM
07/15/19 10:11 AM
ohio
dragon Offline OP
dragon  Offline OP
ohio
Do you run top end lub with methanol I been told not and told you better
Re: methanol [Re: dragon] #2677576
07/15/19 11:36 AM
07/15/19 11:36 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Are you running M1, M3, or M5 methanol?
Read up on it, and you should be able to go from there.
https://vpracingfuels.com/product-category/fuels/racing-fuels/
Re: methanol [Re: dragon] #2678635
07/18/19 11:51 AM
07/18/19 11:51 AM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
Always have. I run top lube and scent.
In fact i also run top lube in all my gas cans for my small gas engines also (lawn mower, power washer etc...) Seems to help keep the crud and corrosion out of the fuel bowls when they sit. Smells good while I am mowing so that's a bonus! LOL
Re: methanol [Re: dragon] #2678709
07/18/19 02:40 PM
07/18/19 02:40 PM
412 SB Duster Offline
We use Klotz Uplon lube in every jug, we fill out of 55gal barrels.
Also i don't drain the fuel system between races.
Al
Re: methanol [Re: 412 SB Duster] #2678963
07/19/19 07:39 AM
07/19/19 07:39 AM
Ct
W
Wirenut Offline
Wirenut  Offline
W
Ct
I run m1 and use top lube. But have never run without it so don’t know what may happen . Fogging the engine and carb afterwards is probably more important. I also filter the meth from barrel to jug and again jug to cell.
Re: methanol [Re: Wirenut] #2683443
08/01/19 01:58 PM
08/01/19 01:58 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
I never thought burning oil was a good idea. Can cause detonation...especially with high horsepower. We do not run it in our car. We also do not flush anything. We race about 12 outings per year.
Re: methanol [Re: BobR] #2683571
08/02/19 01:30 AM
08/02/19 01:30 AM
gregsdart Offline
gregsdart  Offline
Bobr, 15.1 to 1 compression in my 528 wedge, 8.76 at 153 best at 3055 lbs. Never a problem with Klotz in sixteen years.
Re: methanol [Re: gregsdart] #2683991
08/03/19 10:52 AM
08/03/19 10:52 AM
PA
moparacer Offline
moparacer  Offline
PA
I had some issues in the past if there was too much lube added. I ran it without for several years without any issues. Been running lube but thinking of trying it without again.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: methanol [Re: moparacer] #2684205
08/03/19 11:57 PM
08/03/19 11:57 PM
st.louis,mo.
dart games Offline
dart games  Offline
st.louis,mo.
what about with e-85
Re: methanol [Re: dart games] #2684215
08/04/19 01:15 AM
08/04/19 01:15 AM
I don't add anything to the pump E85 I race on with right at 15.0 to 1 compression shruggy
That first motor has over 5 yrs racing on it when I removed it this past winter up
